Zoom clutch is it any good?
Old 06-02-2004, 12:34 AM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
well actualy i should be answering this myself... but here it is why is a Zoom clutch a crapy performance clutch?? mine shakes the whole car when coming off the line when its hot and i dont under stand why? it never slips under heavy accelerating or have any other problims but this, so is it because the clutch pads are so far apart and when its hot it grabs then releases grabs then releases until its all the way engaged causing this shake??? i dont get it??
Old 06-02-2004, 05:51 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I've used Zoom clutches befiore; there's nothing wrong with them. Good quality stuff.
Chatter = you should have had your flywheel turned, it has hot spots
Old 06-02-2004, 07:40 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i have a zoom clutch on my T56.... not the exact same setup as yours, but it seems to be a great clutch.. no slippage, it survived the abuse of stop and go traffic with 2.73 rear and a T56... its survived about 50 hard launches with drag slicks, and its outlasted 2 rear ends... after i have it for a year, i'll post how it lasted... ive only had it in for about 5 months now.
Old 06-02-2004, 08:24 AM
rjmcgee's Avatar
I have had mine for over a year with no problems. It has also seen some abuse.
Old 06-02-2004, 12:51 PM
pasky's Avatar
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I've heard bad things on these clutches as far as durability. Stories of people ghaving to replace them after 3k miles of too much slippage. But then again they were just that....stories. I think if you buy them from autozone you get a lifetime warranty.
Old 06-02-2004, 12:57 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
i dont know about the warranty, but ive put far beyond that on mine, and i abuse it ALOT.... i mean, on a daily basis.
most peoples clutch durability problems stem from improper installation.
Old 06-02-2004, 07:41 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
its a 30 day warantee. my flywheel was resurfaced as well.
TreDeClaw
Theoretical and Street Racing
06-22-2021 08:21 PM
87 camaro iroc
08-20-2015 07:47 AM
redmaroz
08-16-2015 11:40 PM
Street Lethal
08-12-2015 11:33 AM
rsrmoore
08-07-2015 08:44 PM
Quick Reply: Zoom clutch is it any good?
