Mounting tires without a fancy machine...
Old 05-24-2004, 09:58 PM
92RSSlowmaro's Avatar
How exactly do you do it? Ive used a tire machine a billion times, but noone ever showed me how to do it without one? Im assuming you lube it up (With soap, perhaps) and use a prybar of some sorts to take apart the beads? Whats the trick to it, though?
Old 05-24-2004, 10:54 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Why wouldnt you just take the tires and rims to someplace that has a machine? Your probably gonna mess up the rim doing it yourself, A tire place or garage shouldnt charge all that much to do it.
Old 05-24-2004, 11:08 PM
Thanks for the feedback, but that really didnt answer my question...
As for damaging the wheel, im not sure wedging a prybar underneath the bead and rotating the tire will do that. (Im assuming thats what I would do... how, im not sure.)
Old 05-24-2004, 11:28 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
if it was me i'd like to have peace of mind that my tire isnt going to fly off going down the highway because it was put on by some dude with a pry bar and no machine
Old 05-24-2004, 11:33 PM
I thought people actually did this sort of thing.
All you have to do is get it off and back onto the beads.. shouldnt be that hard. Once you inflate it, it will set perfectly. Its awfully hard to **** up, I just need to know the trick to doing it without a machine.
And BTW, if it was mounted poorly enough to fly off, it wouldve deflated before it left the shop.
Old 05-25-2004, 12:01 AM
Car: 1986 Camaro SC
even so, i wouldnt trust it to myself, id rather pay like what is it 10-20 tops.. to get it donw properly
Old 05-25-2004, 12:22 AM
Probably end up doing that. Im sure I could shoehorn them on at home, but its probably more hassle than its worth.
Old 05-25-2004, 12:23 AM
Car: 1986 Camaro SC
yeah i wuld say it is, and also there's proably some law that it ahs to be done by a professionally certified person nowadays like brakes.
Old 05-25-2004, 12:24 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
I've done it with a bumper jack, but car's don't use those anymore much less a third gen! Use wieght to your advantage, set your tire under (front has more weight) where the rotor contacts the tire next to the edge of the rim and let the jack down, and it should break the tire off the bead. Turn it over and do the same thing. After you break both beads, you should be able to get a tire iron between the tire and the rim. Pull the iron back and smack the tire iron with a heavy hammer to work the tire off the rim. The back side of the rim usually has the smallest bead so that's the side you want to take the tire off. Do what you can to protect the rim from scratches (ain't to hard to figure out).
Reverse order to re-instal the tire and add air! Hope this answers your question! Of corse, you will still have to get them balanced!
Old 05-25-2004, 12:58 AM
Yes, that was what I was looking for. Thanks
Old 05-25-2004, 02:04 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
https://www.thirdgen.org/techbb2/sho...e+tire+changer
In that thread RBob [Mod] gave me the key information to make it easy. That bit of info was worth a million bucks.
Old 05-25-2004, 10:53 AM
IROC57TPI's Avatar
4X4 guys usually get the new tire back on the rim and spray the inside of the tire with ether and throw a match at it. It'll make a small explosion, but it'll bead and inflate the tire at the same time. DON'T TRY THIS AT HOME!!
Old 05-25-2004, 11:06 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
That's why 4x4 guy's don't have eyebrows! I always wondered about that!
Old 05-25-2004, 05:14 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Been there done that. The prybar method works on steel wheels, but chews the hell out of the edges of aluminum wheels. If you don't care about your wheels, go for it.
Old 05-25-2004, 07:23 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Yikes, just spend the $35 for your own manual machine and be done with it. The pry bar will work but it would be tough. The only real need for the $35 stand as it hold the tire well and at waist hight. So you can work on it well. It was the best $35 ever spent. I have done $100's of dollars worth of work with it already.
You wont spend better money on a tool.
Old 05-28-2004, 12:30 AM
JP8528V6's Avatar
Car: 1985 Firebird
Engine: 2.8 V-6
Transmission: TH-700R4
off topic slightly, but in response to a reply here...what law stating brakes have to be done by professionals...i've never heard that before...i've been doing my own brakes forever and other peoples too...but yea...putting a tire on a rim...i would rather also take it to my local statino and have my buddy do it for me...
Old 05-28-2004, 08:04 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Sounds like you're a pro then!
I haven't heard of that either; I assume it keeps a "We only change oil" shop from trying to do someone's brakes.
Old 05-28-2004, 10:37 PM
Car: 1986 Camaro SC
yeah? maybe its canada only, but i know that if you get into an accident and somehow they find out your brakes were done youself or somethign you can get in big **** over it
Old 05-28-2004, 10:44 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Funny you say that. I watch the CBC often and keep seeing canada tire / reybest brake pad commercials on how you can easily change them your self. Oh and buy them at ct.
Old 05-29-2004, 12:39 AM
Kj Rockz's Avatar
Location: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Sounds like fun, I would just preffer to fu(k up my tire and rim, rather then pay 10-15 bux to get it installed properly. So i'm with you dood. but when something bad happens don't come whining here.
If you go for it; good luck
Old 05-29-2004, 09:35 AM
This thread is still alive? Interesting.
Anyways, since my family and I are frequent customers at hibdons, they mounted and balanced them for free.
Someday im gonna get one of those machines from harbor freight. Cooool.....
Old 05-29-2004, 03:32 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Awwe I thought you were going to mount them for yourself.
Old 05-29-2004, 07:03 PM
I was going to, until I found out I could have it done for free.
Too bad school is out, we have all sorts of cool toys there I couldve used. I couldve mounted my tires, balanced them, rotated them, done a brake job, and new ball joints in about 4 hours
Old 05-29-2004, 07:17 PM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
ive done it a few times with a prybar and a bumper jack and a pickup
step 1 : breaking the bead
take tire and place under bumper jack and jack up
step 2 : use prybar to pry off tire lube and reinstall
step 3 : inflate to set bead
step 4 : set air pressure to factory specs and install on car
Vintageracer
01-10-2020 05:33 PM
colton_carlson
03-08-2019 12:21 PM
Polo Z03
Wheels and Tires
49
07-21-2017 12:31 AM
Scamo-2.8
05-20-2016 07:01 PM
LT1Formula
11-16-2015 01:13 PM
Quick Reply: Mounting tires without a fancy machine...
