DFI and ECM Discuss all aspects of DFI (Digital Fuel Injection), ECMs (Electronic Control Module), scanners, and diagnostic equipment. Fine tune your Third Gen computer system for top performance.
DFI 6 ECU Info
Old 05-19-2004, 08:30 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
DFI 6 ECU Info
The ECU/ECM for a TPI was a 74022, in a kit...however, a stand alone or replacement TPI ECU was part # 74046 (which I apparently have)
The calibration file for a stockish TPI 350 is the 74022.all
If the DFI is equipped to use a narrow band O2 sensor, the cal file is 74022A.all
The LT1 cal file (using the 74022 or 74046 ecu) is 74022L.all
The 74023.all is for a 383
The 74024.all is for a 400
I spoke today with Mike at DFI Tech Line, and he was VERY helpful. He stated that the above calibration files were tuned on the dyno initially with these cubic inch engines and should be GREAT base file.
The 74022A (o2 sensor kit) should be pretty spot-on for a stockish TPI 350, but will be a bit rich. Mike reminded me that these are only a base file and still need some tuning for each combo.
Also, he reminded me that a base calibration file can be made using Calmap 6.32, which is what I have and is a free download from the Accel DFI site.
HTH Someone Else....
KO1
16
10-15-2015 05:00 PM
bjpotter
10-04-2015 07:48 PM
Linson
10-01-2015 09:50 PM
efiguy
09-27-2015 01:30 PM
Quick Reply: DFI 6 ECU Info
