If the computer is bad will the car still run?
Old 03-08-2001, 01:42 AM
Josh 91RS's Avatar
I know that my fuel pump is bad, and the computer may be bad also. If i replace the fuel pump, but the computer is bad will the car still run? Need to replace the fuel pump this week to get it running again.
Old 03-08-2001, 09:59 AM
Ovrclck350's Avatar
From my experiences....NO. The computer controls fuel delivery, and therefore since it's not telling the delivery, your engine's not getting any....
Old 03-08-2001, 10:31 AM
Blade's Avatar
It depends on what part of it is bad. Sometimes the car will run fairly good, ****ty as hell or not even start. It all depends...
92 Z28 5.7
Ported stock heads, XR270HR-10 cam, TES headers
Crane AFPR, Flowmaster catback, MSD ignition
#24 SVO injectors, 1LE aluminum driveshaft.
Best ET 13.3@107 mph
Click here to see my car at Truspeed.org
Check out Truspeed
Check out the Bin Archive
Old 03-08-2001, 01:01 PM
theformula's Avatar
If there is a computer problem, the car will sometimes go into Limp Home mode.
Old 03-08-2001, 11:40 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
A bad computer can do just about anything, it depends what's wrong with it. Sometimes the car won't run at all, and other times it'll run, but in limp-home mode. Or it could be intermittent, like mine was. The computer would spontaneously cut out the injector pulses, but then work fine a few minutes later. I'd say to put the new fuel pump in and see how the car runs after that.
Old 03-09-2001, 03:05 AM
Josh 91RS's Avatar
The mechanic said it was giving an intermittent Signal to the fuel pump relay. So with that said do you think it will still run?
Old 03-09-2001, 08:47 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Now the question is what is the cause of the intermittent signal? My suspicion would be a short/break in the wiring from the ecm to the fuel pump more than the ecm itself. Do the fuel pump first as they commonly go.
Generally, when I have had "electronic" things go; they just die.
Get an ecm from a wrecking yard (a lot cheaper there) and try it out if you have doubts about your ecm. You don't mention what engine you have, so I can't mention other potential donors. With TPI, you can snaffle the ecm out of a early SD MPFI V6 out of virtually any GM car (except W bodies).
Thus a Lumina, Corsica or Berretta (along with V6 Firebirds) are all potential donors. I know that the 7730 ecm from a Lumina is like $20-$25 where as a 7730 ecm from a SD TPI V8 F-body is more like a $100 from the wrecking yard. Same ecm, just more money.
Old 03-09-2001, 09:08 AM
theformula's Avatar
Just go to Autozone to get your ECU. A friend of mine picked his up for $80
86IROC112
08-17-2015 02:00 PM
squiggy2
08-09-2015 09:30 PM
1992 Trans Am
08-08-2015 08:16 PM
mustangman65_79
08-08-2015 12:07 PM
3rdgenparts
08-06-2015 09:03 AM
Quick Reply: If the computer is bad will the car still run?
