Chrome plated cylinder walls
Old 03-04-2001, 07:41 PM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
has anybody done this? I heard that if you do this your engine will last forever....almost
1985 Z-28, tpi, basically stock......so far
SEE YOU LATER INTIMADATOR
R.I.P. #3
Old 03-04-2001, 07:42 PM
Jason M 91Z's Avatar
Where'd you hear this? A chrome plater?
-Jason M. 1991 Camaro Z28
Old 03-04-2001, 07:59 PM
Car: 1985 Z-28
Engine: a big one
No they chrome plate small engined aircraft(cessnas, and pipers) and they go 2000 hours between overhauls. anyway, chrome is harder then steel, and the walls shouldn't deform. plus as an added benifit they can make the plating thicker at the top of the cylinder to make more compression.
anyway chrome should keep the cylinders from getting egg-shaped and all goofed up.
I will probably be doing this to my 400
Old 03-04-2001, 08:07 PM
406 S10 Man's Avatar
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
good luck. you will never be able to get you rings to seal. most of us high performance guys don't really worry about the life of their engines. i will probably get bored with my current combo long before it wears out.
88 S10
Dropped 3/4
18" Boyd Coddington Timeless 5s
Dart equipped 406
12.20 @ 115.25 mph
Old 03-04-2001, 08:12 PM
Car: 1985 Z-28
Engine: a big one
I don't know how they get them to seal, but I guess it would have to be possible. the onlything that I am worried about is going through the block, 400s in my area are extremely rare, and I could easily get about 800-1000 for the block alone.
so ring sealing would be a problem, are there any other problems with the chromed walls?
Old 03-05-2001, 10:18 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
You don't have to chrome plate the cylinder walls to make them last long. Synthetic oil, regularly changed, high volume oil pump, and keeping it cool will make it last a long time. My 400 is from a 73 Malibu, and god only knows how many cars its been in. Im sure it has at least 200,000 miles on it. For some reason, 400s last a long time. I believe its because they dont have to rev very high to make power. I can drive all day and never go over 2000 RPM! Anyways, good oiling and cool running will keep your engine lasting forever. BTW, Cessna engines can go so long between maintenance because they are engineered for simplicity. They have no timing advance whatsoever and they have magnetos instead of distributors so the engine will run with no battery, and other stuff to make them very reliable. The chrome plated cylinder walls don't have much to do with it.
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
Clarion 45X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine"
Old 03-05-2001, 11:19 AM
burnoutrpm's Avatar
rings wont seal at all least it'll look good!!!but you cant see it from the outside. so it aint worth it! put the money you want to use on that crap, and put it into something else!!
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
434 casting completely redone with bronze guides and 202/160 valves 64cc chambers. decked .0005 thousandths
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old 03-05-2001, 11:53 AM
Tom 400 CFI's Avatar
Car: '92 Corvette
Transmission: ZF6
Axle/Gears: 3.45
The rings will seal correctly, if you use the correct rings. There are many examples of engines that use chrome bores from Rolls-Royce, to Mercury Outboard engines. The cylinder will last longer than a plain cast bore, but a cheaper alternative is NiCaSil coating.
Either way I don't think it is worth it in a car engine. A well maintained engine will pretty much outlast a car anyway, unless you do a complete restoration.
Old 03-05-2001, 03:04 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
This is definitely a new one on me.
In all I've read over lots of years, I've never come across this being done to an auomotive engine.
Normal cylinder wall prep calls for a 60 degree cross-hatch pattern to remain after the honing is complete. This pattern holds a tiny amount of oil to lubricate the rings to prevent excess wear. Chromed walls won't have this and I'll bet ring life will be very short.
Unless I could find some positive, hard data on the long term effects of this mod, I'd skip it.
Now hard chroming a crank shaft is a different matter. This mod has proven effectiveness and hardens the journals against abrasive/oil dilution wear. Since the journal/bearings are under oil pressure, no cross-hatch is needed or even desired.
Sometimes very smooth is good; sometimes it ain't.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
[This message has been edited by JakeJr (edited March 05, 2001).]
Old 03-05-2001, 06:48 PM
Car: 1985 Z-28
Engine: a big one
hmm, I didn't know that there would have been problems with chrome plated walls. But the journal bearings being chromed intrigue me. What would be really neat, is if you could teflon coat the bearing surfaces, teflon has one of the lowest coefficients of friction known to man.
Old 03-05-2001, 07:07 PM
84TransAm's Avatar
Chroming the cylinder walls like in a single engine (or twin) airplane is not a good idea. First the airplanes are designed to perform for extended periods of time at a LOW engine RPM. second, automotive technology is light-years ahead of single engined aircraft. Most Cessnas and Pipers running around are leftovers from the 50's-70's.
Lastly, the airplanes run off of lead fuel. I know some drag engines run off of the 100LL stuff too, but if you plan on taking it on the street, forget it. 100LL is expensive stuff ($2.32/ gallon i believe) JET A is a bit cheaper, but still not easy to find.
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
NOW FEATURING: Holley 600 cfm & vacuum advance
Old 03-05-2001, 07:30 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Let's go back to your statement about the cylinder walls deforming: The chrome won't stop it. The chrome is intended only as a wear surface, not a strength-adding coating. The chrome is very thin; it's hard, but brittle so not "tough". If the cylinder walls flex behind the chrome, the chrome will crack and peel off - doesn't sound too good, does it.
The surface prep has to be perfect before the chrome is plated. Any dirty spot or improper roughness will leave a "bubble" that will chip right off. Guess what, after that happens? Same as above.
It is feasible, and yes, special rings designed for the job would be required. But, do like Ward says and you're just as well off and you've spent a lot less money.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old 03-05-2001, 11:04 PM
JP84Z430HP's Avatar
Car: 84 Z28
Axle/Gears: 9-bolt, 3.27
When I saw my LG4 pass 200,000 miles on Valvoline mineral oil, I even wonder about synthetic! My 355 will have synthitic in it, though, but just because I'm picky about $3500+ engines.
I don't really see where it would be worth the cost of having it chromed (Hard chrome, I'm sure). and the special rings that would be required.
As a side note on the synthetic, a buddy was doing the math on it, and for the difference in cost, if you run 150,000 miles, and have to replace the long block, you still would've save money on the oil changes. As I said though, I will have synthetic in my 355.
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand.
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Old 03-06-2001, 12:08 AM
five7kid's Avatar
Engine: LS1/LQ4
<font face="Verdana, Arial" size="2">Originally posted by JP84Z430HP:
</font>
Wouldn't save money with which option, petroleum or synthetic? If the latter, you need to redo some math.
If you change synthetic every 3000 miles you (pick one or more below): 1) have a tuning/mechanical problem; 2) are using a cheap synthetic; 3) are used to lighting cigars w/$20 bills; 4) are ignorant; 5) are ****; 6) have had something else chromed (there, now we're back on topic...).
Old 03-06-2001, 01:27 PM
johnyIROC's Avatar
Chrome is a bad idea.... if it flakes your engine will 'esplode
Old 03-06-2001, 01:49 PM
Car: 1985 Z-28
Engine: a big one
okay okay, I think that I am not to enthused about chroming the walls. I have also heard about the cost, and now I am thinking.....not untill I am a gazillionaire, even then I could blow up an engine everyday, and i still wouldn't care. that would be the life
Old 03-07-2001, 08:26 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I don't run synthetic for it's help with wear, i run it for fuel savings. In my 85 i started making a solid 2-3 mpg better when i switched to sythetic.
And 57, i'm the lighting cigars w/ $20 type i guess, i still change every 3k miles. I like clean oil, what can i say. I'm waiting for the amsoil pitch though, you sound like thats where you're leading to...lol
...ed
Old 03-07-2001, 09:24 AM
88SC's Avatar
This process is widely used in the aircraft industry. Read this, it explains the process and some of the other questions that came up:
http://www.sentrya-ccylindersinc.com...chrome_101.htm
The fact that the process is FAA certified means that someone has tested it extensively. It works rather well.
However, to use it on something other than an aircraft engine means that they'd have to do a special set-up. They're not used to dealing with engines that have integral cylinders, and there's no experience base with cast-iron cylinders, etc.
Old 03-07-2001, 08:30 PM
IROCeastTN's Avatar
Hey guys, this is an interesting subject for cars. I have a 1999 Yamaha YZ400F, thats a 400cc 4-stroke, if your not familiar with motocross bikes. It has a plated cylinder and it turns 11,200 rpms. It's also a five valve single cylinder screamer. Like someone said above I don't think they can plate to an iron cylinder like in a standard sbc. But if you had a aluminum one it would be great for a high rpm motor. It reduces friction and prolongs ring life. The local bike shop owner here had his old bike sleaved with a cast iron one, and it just would not rev like it did before, so he had it resleaved with an aluminum one and plated and now she screams again! This would probably not be worth the cost in a motor that never sees the high side of 6000 though. Oh yeah just wondering what the hp/cubic inch would be for my YZ. 400cc/55hp 235pounds. Its fast. Going to take it to the strip and run it against the IROC this spring in the 1/8.
later, eastTN
88 irocz fresh 350 tpi eibach springs, weld draglites, 1 3/4 hedman shortys, flow master, march aluminium underdrive pulleys, T.B. coolant bypass, accel 300+ race wires, 180 thermostat, accel flow booster, 2 lower walls removed from stock uppper plenum, 700r4 with 2500 stall, B&M shift kit, corvette servo, kevlar frictions, K&N filters, emissions delete
manualbrakes.com
Brakes
63
04-09-2024 11:55 AM
Hotrodboba400
12-10-2019 07:07 PM
69GTOby
04-18-2016 02:34 PM
sreZ28
10-22-2015 08:21 AM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Chrome plated cylinder walls
