89 to 91 fuel pump relay harness wires
Old 04-07-2004, 08:29 AM
The Shadow's Avatar
Car: 1989 Camaro RS
Engine: 305 V8 TBI
I have 89 RS TBI with a 305. The fuel pump relay harness has been cut off by the previous owner. I have a 91 harness and relay but the wires are missing. Does anyone know what colors match up? The 89 wires coming from the car are solid red, solid purple, black with red stripe, and green with white stripe, and tan with white stripe. The solid red and solid purple are thicker gauge wires than the others. The 91 harness has a solid red wire coresponding to (A) on the harness (thick wire) solid black (F) thin wire, solid purple (E) thick wire, and solid orange (D) thin wire.
the 89 GM#14089936 the 91 GM#14103304
Old 04-10-2004, 08:24 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Go to this link GM-ECM drawings . All the info you need is there.
RazorN8
01-07-2022 11:44 AM
89GTAOz
05-16-2020 09:31 AM
Infested
05-22-2018 11:56 PM
mustangman65_79
04-14-2017 05:37 PM
Kaweh
08-09-2015 02:54 PM
Quick Reply: 89 to 91 fuel pump relay harness wires
