700r4 HP and torque Rating
Old 02-04-2004, 04:36 PM
Roads88's Avatar
Car: 1988 Pontiac Trans-AM
Engine: TPI 350 (5.7L)
Anyone know the HP and torque rating of the 700r4 Trans. I may have to have mine rebuilt. I would like to know what the factory specs are before I have it done.
For example: If I decide to put a 350 hp motor in the car will the trany need to be built up.
I have done a few things to the motor( see sig) and need to know were the line is. The car will most likely never see a drag strip. Thanks
Old 02-06-2004, 01:05 AM
MdFormula350's Avatar
https://www.thirdgen.org/techbb2/sho...4+stock+handle
Old 02-06-2004, 01:10 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
if its an untouched stock tranny, id personally get it rebuilt and built well. 700's are weak. And its torque, not hp that will kill it
Old 02-06-2004, 01:26 PM
Roads88's Avatar
Thanks for the info.
I agree torgue is the major killer.
The link posted provided the info: its around 325 hp and 400 ft lbs. of torgue.
If im going to drop a bunch of money getting it built up, Im may just go whole hog and get a T-56. I wanted a stick when I got the car, but they just didn't make them,...sigh.
Odds are it will be a long time befor I can do that. So a standard rebuild may be the order of the day and in a year or so get a t-56.
Thanks again.
Old 02-06-2004, 07:37 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
At the very least get more 3-4 clutches and use a Vette servo. A good shift kit and the trans will hold up for much longer than you think.
I just swapped in the T56 when mine went, but I also had the money at the time.
Old 02-07-2004, 11:27 AM
Roads88's Avatar
ok, Thanks
did you do thew swap yourself? If so how much time did it take and did you get the car on a lift?
Old 02-07-2004, 08:40 PM
I did the swap myself. No access to a lift at the time. I used 4 jackstands and a couple of 4x4s to get the car up in the air high enough.
It's tough to say how long it took. I did a lot of other things while I was doing the swap. I built a complete new dash out fo steel and aluminum for one, and that took a lot of time. I also completely rebuilt my trans before I swapped it in, plus I added a steel 3-4 fork.
If I just had to do the swap I'd say a full weekend wouldn't be a problem if you have everything on hand, all the tools you need, adn a friend to help you wrestle with the trans.
Old 02-08-2004, 01:49 PM
Roads88's Avatar
84LsxZ28
05-17-2020 02:21 PM
plm99
Southern California Area
11-16-2015 05:21 PM
luvofjah
09-26-2015 08:28 PM
HikoriYami
09-21-2015 07:11 PM
89newfun
09-16-2015 09:28 AM
Quick Reply: 700r4 HP and torque Rating
