use sealer on water pump gaskets?
Old 01-26-2001, 10:44 AM
zee28's Avatar
Car: 86 iroc
should i put sealer on the water pump to block gaskets?I have heard with and without is best.and if yes,should I use red/high temp sealer or what?on a 86 lg4.I know I have to put it on the bolts.thanks
Old 01-26-2001, 10:49 AM
R.O.B.'s Avatar
I always use RTV Blue, never had a problem yet.
Rob
'86 TA 305 TPI
Old 01-26-2001, 12:02 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I've used Permatex Hi-Tack (red) brush-on sealant for water pump (and thermostat/timing chain/rear axle) gaskets. I've used the Blue RTV on the bolts.
Vader said to use something else on the bolts.. something that doesn't harden like RTV; but I forget what it was called...
Old 01-26-2001, 12:40 PM
MadMax350's Avatar
Car: 1987 Pontiac Fiero
Engine: 3800 Series 2 Turbo
Transmission: 4T60-E
Axle/Gears: 3.33
I would not use high-tack. You can use just about any RTV you would like on the gaskets. Using RTV will also make it easier to get the gasket off if you ever removed to water pump as well. The bolt sealing should be done with FelPro Grey Bolt Prep.
1987 Trans Am GTA WS6
-5.7L SuperRam
-TFS Twisted Wedge Heads
-LT4 HOTCAM
-LT1 PM Rods
-4L60-E Transmission
-LS1 Aluminum Driveshaft
-4.10 SRD
1988 Pontiac Grand Am
-3800 SFI V6
-125-C Trans
-Stock 2.5L converter (stalls at about 3000)
-Stock emissions equipment
Domestic Terrors Car Club Online
Old 01-26-2001, 05:24 PM
ede
ede's Avatar
i use high tack on the bolck and water pump and tefelon pipe sealer on the bolts.
ICON Motorsports
1st & 3rd
Old 01-26-2001, 08:14 PM
Vader's Avatar
Zee,
Ede got to it before I could. The main thing to remember is that the factory uses NO sealer on most engine gaskets. The biggest difference between them and us is that they have clean castings and stampings. If you take the time to clean the surfaces completely and thoroughly, you don't need a sealer.
If you want to make sure, a very thin application of a non-hardening sealer can be used. RTV is O.K., and I've used both brush-on and spray-on Permatex Hi-Tack red with good success. I treat all engine bolts that enter the water jeacket with Permatex PST pipe sealant. This is different than regulat teflon pipe thread compound, since it does take a "set" and seals straight threads better. Most pipe joint compounds are intended to be used on tapered pipe threads, with much smaller clearances to fill and seal. There are other brands of head bolt sealers that work just as well and are similar, but I don't know any of the names off the top of my head.
Later,
Vader
"I'm gonna talk about some freaky sheet now..."
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
[This message has been edited by Vader (edited January 26, 2001).]
evilstuie
01-09-2020 08:29 PM
Chuck84TA
07-15-2016 09:05 PM
Bubbajones_ya
08-28-2015 02:17 AM
1985chevydude
08-22-2015 05:36 AM
Dialed_In
08-20-2015 01:45 PM
Quick Reply: use sealer on water pump gaskets?
