Does anyone have an actual CAM CARD for GM's LT4 HOT cam??
Old 01-27-2004, 03:35 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I know the specs @ .050 lift 218 228, .525 lift with 1.6, .492 with 1.5 rockers. I would like a cam card to help me better degree in the cam for my friends buildup. I need IVO, IVC, EVO, EVC events. Thanks!
Old 01-27-2004, 08:34 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
not a cam card. but according to DD2000 the LT4 hot cam numbers are as follows:
IVO = 0.3
IVC = 38.8
EVO = 49.1
EVC = -0.2
hope this helps.
Old 01-28-2004, 11:42 AM
GASGZLR's Avatar
What intake centerline did you use when you entered those specs? I know the lobe sep is 112 but what's the darn centerline #?
Old 01-28-2004, 11:53 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
It's probably ground with 108* ICA since most small block Chevys operate best with 4*, but that doesn't matter. You can make it whatever you want.
The specs mrr23 gave put it at 109.3* ATDC if that helps.
Old 01-28-2004, 04:48 PM
mrr23's Avatar
Engine: 360 HSR
i didn't put those in. these specs came with the program
lobe center 111.9
oh yeah and theses specs are at .050 duration.
Old 01-28-2004, 06:32 PM
smithtc's Avatar
icl intake 109 degrees
icl exhaust 115 degrees
@.006 272/281
@0.050 219/228
ls 112
lift 328/328
Specs from my 24502586 Hot Camshaft
smithtc's Avatar
Old 01-28-2004, 06:36 PM
AJ_92RS's Avatar
I never said you did. Read.
Old 01-29-2004, 01:29 AM
Black 91 Z28's Avatar
This link has the events at 0.05
http://www.sallee-chevrolet.com/wwwb...sages/132.html
David
Old 02-03-2009, 08:44 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Does anyone have an actual CAM CARD for GM's LT4 HOT cam??
I'm bringing this back up.
I've been searching the web for over 30 minutes and it seems nobody has a cam card for the LT4 hot cam.
If anyone has the car info or has degreed the cam themselves please post the specs from the card!
Thank you.
Old 02-03-2009, 08:47 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
These specs just turned up.
Can anyone confirm these?
Intake open: 30.5 BTDC Intake close: 68.5 ABDC
Exhaust open: 78.5 BBDC Exhaust close: 28.5 ATDC
Old 02-04-2009, 07:02 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Looking for the .050" specs.
anyone?
Old 02-04-2009, 07:55 AM
zipfast's Avatar
Car: 94 9c1 Caprice
Engine: LT1 (3-fity)
Transmission: 4L60E reBUILT
Axle/Gears: 3:08 POSI (out)
Thats the same as POST #6, and #2 which is @.050
rounded off...
IVO 1
IVC 39
EVO 50
EVC 0
Old 02-04-2009, 08:03 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
rounded off...
IVO 1
IVC 39
EVO 50
EVC 0
I saw that but was wondering what was actually on the cam-card or if anyone had checked it with a degree wheel.
Thanks for your reply.
Old 02-08-2009, 11:29 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
ttt
I'd like to eventually get the info here so it will show up if someone searches for this.
Old 03-15-2010, 11:01 AM
95talonawd's Avatar
Car: 2001 Camaro SS
Engine: LS6
Axle/Gears: 4.10
Old 04-14-2010, 03:36 PM
Curious_George's Avatar
Car: '87 IROC, '92 & 99 Corvette Vert.
Engine: L98, LT1, LS1
Transmission: L98 = 700R4
Axle/Gears: L98 = 3.23 G92
The Lunati 50143 is very similar to the LT4 Hot Cam. I would venture to say it is identical for all intents and purposes.
219 / 227 (@ .05" lift)
.471" / .480" (1.5 rocker ratio)
IVO - 1.5*
IVC - 37.5*
EVO - 49.5*
EVC - -2.5*
Centerline - 108*
Lobe Separation - 112*
CG
Old 06-08-2010, 04:15 PM
On Probation
Atilla the Fun's Avatar
Car: seeking '90.5-'92 'bird hardtop
Engine: several
Transmission: none
Axle/Gears: none
It's a better choice for Vortec heads.
junkcltr
08-02-2019 11:12 PM
lt1z350
08-28-2015 05:57 AM
bdads
DIY PROM
08-24-2015 06:01 PM
1988iroc350tpi
08-14-2015 07:52 PM
anesthes
08-08-2015 09:37 PM
Quick Reply: Does anyone have an actual CAM CARD for GM's LT4 HOT cam??
