L31 Combo (carb+cam)
Old 01-09-2004, 10:42 AM
Mohammed's Avatar
Car: 88 IROC-Z
Transmission: 700-R4
I’m new to the carb world, need a good combo for my 89 to replace the TPI’d LB9.
Gonna use an L31 from the yard and the is Performer RPM Air-Gap intake what cam and carb should make it a killer? Trans is WC-T5 with 3.42 gears. Don’t have any pollution laws here but I’ll be driving it on the street.
Thanks for your input
Old 01-09-2004, 11:48 AM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
take the heads off, take them down to a machine shop, have them cut the valve guides down, and make the valve seat larger, for a larger valve spring. while the heads are there, you might as well have them drill and tap the rocker stud bosses for screw in studs. should be pretty cheap, call around and get some quotes.
replace the head gaskets (probably a good idea anyway)
a factory L31 has a roller cam, so you might want to go with something like a comp XR270HR-10, or XR276HR-10.
both should give you good power up to about 5500rpm, so it should be plenty streetable.
as for a carb, a holley 4150 650cfm should work just fine, word around the campfire is that mechanical seccondaries are reccomened for a manual car, and vacuum seccondaries are reccomened for a auto car.
Old 01-09-2004, 01:26 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Holley has a chart on their website that shows what RPM (stall speed) you need to stay above to avoid bog with a given engine & carb size for a mechanical secondary (double pumper) carb. A 650 DP works well on a 350 for fairly low stall.
Old 01-11-2004, 05:01 AM
Mohammed's Avatar
Car: 88 IROC-Z
mate do you have the link for the chart?
Old 01-11-2004, 05:06 AM
Mohammed's Avatar
Car: 88 IROC-Z
Will I get more power with the Holley 750 DP?
Old 01-11-2004, 10:56 PM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
If you want big screaming power here ya go:
A. Use a Holley 750 DP
B. Use an Edelbrock Super Victor Vortec Single plane intake and have it port matched to the Vortec heads you have.
C. Choose a cam lobe from this link and go from there. http://www.carcraft.com/techarticles/116_0311_cheap/ Scroll down and click on the small yellow chart above the Royal Purple oil quarts. Those are some mean cam specs that you would want probably. You can go with larger lift cams if you read D and follow suit.
D. Are you willing to spend money to take that engine apart and modify the heads? It's worth power. You could machine the valveguides down to accept MORE than .485 lift which is the maximum you can run with stock Vortec heads. Also since you'll be choosing a killer camshaft, bigger stiffer springs would be a wise choice. A performance oriented valvejob would be worthwhile also along with pocket porting and smoothing of the runners, maybe even combustion chamber polishing. If that's something you want to do, you can then just get a bigger cam to start with instead of a small .485" lift cam. Aftermarket Roller rocker arms would also enhance high rpm operation while adding power.
This is what the "Cheap Street" racers are doing and ya know...with a 175 shot they are running high 9's and probably making 600+hp...Goodluck!
Old 01-12-2004, 11:37 AM
five7kid's Avatar
Engine: LS1/LQ4
http://www.holley.com/HiOctn/TechSer...fo/TI-225.html
Old 01-12-2004, 11:40 AM
five7kid's Avatar
Engine: LS1/LQ4
A little better WOT off-the-line.
Peak power will be about the same whether DP or VS. It's the rest of the curve that benefits from the DP.
Linson
09-25-2021 07:55 PM
InfernalVortex
04-20-2021 11:31 AM
FormulasOnly
07-23-2018 08:47 AM
roysatikas
09-22-2015 08:15 PM
sandman92084
09-12-2015 10:27 PM
Quick Reply: L31 Combo (carb+cam)
