TBI TO CARB - wiring fuel pump?
Old 01-09-2004, 08:59 AM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
I'm in the middle of a carb swap and need to know how to deal with my fuel pump. Does it have to be hot-wired with the TBI/EGR/distributor systems removed? Where does the computer get the signal to run the pump after the initial 2-3 second run when u turn the key (before the car turns over)? Help me out guys, I'm stumped.
Ty
Old 01-09-2004, 09:06 AM
scauffiel's Avatar
Why do you guys insist on removing all of the wiring? Blows my mind. Once you start tearing out crap, you remove any kind of "common ground" with the folks around here and have a helluva mess. Leave the wiring in place. Hook up carb. Install regulator. Reduce pressure to 5-7 psi. Done deal.
S.
Old 01-09-2004, 11:54 AM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
hold on buddy, i haven't removed any of the wiring. I just removed the tbi/distributor/egr (the hardware - the wiring is still there, the whole harness is still in tact) - but I figured that the computer got the signal to run the pump from the distributor spinning or something. How does it work?
Old 01-09-2004, 12:02 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The computer gets its signal that the engine is cranking/running from the dist. reference pulse. When it sees the pulses, the computer triggers the fuel pump relay. The pump will still operate the way it is. There is a backup switch above the oil filter that closes at, i think, 4 psi. The stock oil pump will have to turn a bit to build oil pressure before the car starts but its not too big of a deal. If the motor has a high pressure/high volume pump it will close almost immidiatly. My goodwrech builds around 35 psi when cranking and it would close the switch as soon as the engine cranked.
Old 01-09-2004, 12:19 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
hey demented - (i think you're my new best friend)
so what you're saying is that the sensor above the oil filter (which i thought was an oil-dummy-light-sensor) is actually for the fuel pump?
As long as I leave that switch hooked up, my fuel pump needs no tweaking then right? (i have a high pressure oil pump too...)
Ty
Old 01-09-2004, 12:22 PM
Brent's Avatar
NEVER EVER hotwire the fuel pump to the ignition switch.
If you have an accident and the fuel lines are torn there is nothing to stop the pump. You could have a roaring inferno in short order.
Like was mentioned, use the factory oil pressure switch to run the pump.
Old 01-09-2004, 12:23 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you can.
just use a rollover switch like fords have.
Old 01-09-2004, 12:28 PM
chevypower's Avatar
Car: '89 Formula, '97 Z28, '88 Formula 350
Engine: 305 TBI(LO3)
Transmission: TH700R4(MD8)
That switch is the oil pressure/fuel shut-off sensor. It does also work your oil pressure guage in the dash. 4psi is also correct.
Old 01-09-2004, 12:58 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
so bottom line: as long as that sending unit above the oil filter on my 1988 tbi car is hooked up, my fuel pump will run, right?
Thanks fellas
ty
92camaroJoe
07-29-2023 07:57 PM
theshackle
03-05-2017 06:37 PM
Jae992
08-27-2015 09:07 AM
beachrodder
08-25-2015 08:05 AM
92camaroJoe
08-13-2015 06:07 AM
Quick Reply: TBI TO CARB - wiring fuel pump?
