Double vs. Bubble Flares
Old 12-16-2003, 06:10 PM
colonboy14's Avatar
Car: Trans Am
What's the difference between double flares and bubble flares? If someone could draw a picture in Paint or something that would be great.
Old 12-16-2003, 07:17 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Double flare is on the left, bubble on the right.
Old 12-17-2003, 06:57 AM
colonboy14's Avatar
Car: Trans Am
Are they both commonly used? And how does the bubble flare seal?
Old 12-17-2003, 04:45 PM
The double flare uses the standard SAE thread fittings; while the bubble flares use metric fittings, and are used on most, if not all, new vehicles today. GM started converting over to the metric ones in the mid 80's.
The bubble flare seals on the outside of the 'bubble', where the inverted nut squeezes it into the fitting.
Pete
hectre13
Car Audio
26
03-03-2022 05:38 PM
skinny z
10-05-2015 06:23 PM
BWilcox
09-20-2015 12:19 PM
84redta
09-19-2015 09:58 AM
romcjr
09-17-2015 05:18 PM
Quick Reply: Double vs. Bubble Flares
