Oil blowing out of breather...??
Old 12-24-2000, 03:37 PM
super chevy's Avatar
Puzzling problem. Put a new motor in my friends El Camino a month ago. Includes TrickFlow heads and running about 10.2:1 compression. Here's the problem; ever since the install, oil has been blowing out of the valve cover breather. We checked the PCV valve (new) and it is good, and is connected to the right port on the carb. The breather was an Erson chrome push-in style that was on the old motor. We installed a new Chevy chrome push-in breather. Same problem. We installed another PCV valve. Same problem.
Maybe we're overlooking something.
Any suggestions?
Thanks,
SC
Old 12-24-2000, 05:17 PM
SGT SWEETPANTS's Avatar
I have absolutely no idea what the problem is, but may have a way to fix it anyway. They make valve covers with baffles to keep the oil from splashing in there so much and to keep the rockers oiled better. If you can not figure out any other way to stop it, this may be a good idea. One draw back to these valve covers, however, it takes about 2-3 minutes to put in each quart of oil.
'86 IROC-Z
305 LG-4, T-5
T-Tops
50k Original Miles
K&N Air Filter
Stage I Chip
KYB Shocks/Struts
Centerforce Dual Friction
Old 12-24-2000, 05:20 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
My guess is a lot of blowby...if it was a fresh rebuild, it may take a while for the rings to seat themselves to the bore; or it could be the rings were incorrectly gapped (ie. too large a gap); or even the wrong oversize pistons: .030 over into an .040 over bore.
Pete
Pete's Place
HiOutput Virtual Racing Team
Old 12-24-2000, 05:51 PM
ede
ede's Avatar
i was thinking rings installed up side down? if it's a new engine i would give the rings a chance to seat.
ICON Motorsports
1st & 3rd
Old 12-24-2000, 05:54 PM
CamaroZ_85's Avatar
are you using synthetic oil for the break in? you need to use natural oil in order for everythin to seat properly...
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
Old 12-24-2000, 06:22 PM
It's a new motor. Built and dyno'ed by a local speed shop. Has about 900 miles on it at this time. No synthetic oil. Is using what seems to be an abnormal amount of oil, but not blowing out the tailpipe. Runs VERY strong, just this breather problem.
SC
Old 12-24-2000, 09:59 PM
87Z-ya's Avatar
I had this problem with one of my motors. The cure for me was this. I had the pcv in the back of the valve cover going to a port on the rear of the carb. This motor didnt like it and puked oil also. I moved the pcv to the hole that the breather was in. It was in the front of the cover and it made sense that the blowby would come out the tallest part of the valve cover.This solved my problem. The breather is in the back and the pcv is in the front.
[This message has been edited by 87Z-ya (edited December 24, 2000).]
Old 12-25-2000, 01:14 AM
Bort62's Avatar
Pull out the Dipstick and Rev the engine, Do you see atomized Oil Blowing out ?
If So, You got some Massive Blowby.
if Not, Then you are prolly okay, Just get a Breather With a Foam insert In It to seperate the Oil My Buddys Nova is pusing 500Hp and it Blows the Breathers out On Occasion
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Livin' the Stereotype
Old 12-25-2000, 07:52 AM
ronterry's Avatar
Car: '94 Corvette
Had the same problem, solved by putting both beathers on the driver side.
No PCV...screw that emissions crap.
Ron C. Terry
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
Old 12-25-2000, 01:58 PM
CamaroMike's Avatar
PCV's are not emissions crap! They take harmfull combustion gasses out of the crankcase before they contaminate the oil and raise it's acidity.
NOW TO SOLVE YOUR BLOWBY PROBLEM!
Do your valve covers have baffles in them were the breathers go? If the valve covers are cheap then they won't have baffles and oil will puke all over the valve cover. Get a GOOD set of valve covers with baffles and your problem should go away. If it does'nt then you have ENGINE TROUBLE.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
91 Firebird 5.0L TBI
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Hotrodboba400
12-10-2019 07:07 PM
tyeo098
11-30-2015 06:27 PM
Stryker412
09-20-2015 06:59 PM
CatmanFS
09-19-2015 09:00 AM
90formulaVortec
09-03-2015 09:26 AM
Quick Reply: Oil blowing out of breather...??
