How do I fix this hood dent myself?
Old 11-12-2003, 10:03 AM
kanuck's Avatar
Car: 1982 Trans Am
Engine: 350 Crate
The very front of my hood and front nose has a basketball size dent in it. Just to the driver side of the centre of the hood. It's mostly on the nose, but the edge translates to the hood. It was there when I bought the car. The paint is intact on both the hood and nose (no spiderwebbing either). I’ll probably try to remove the nose and am not really worried about it. But the hood is steel and I’m wondering if there’s a way I can temporarily “shape” it back, at least to get it close to where it’s supposed to be.
Any techniques with a rubber mallet and 2*4 or something else I could try? Down the road, the car will go to a body shop for dent repairs and a paint job, but I just want to bang it back myself for now since it’s kind of an obvious one.
Hope the pictures show what I’m talking about, it’s hard to see the dent in pictures.
Old 11-12-2003, 10:04 AM
kanuck's Avatar
Car: 1982 Trans Am
Engine: 350 Crate
An edge shot where you can kind of see how it droops a little on the driver side.
Thanks for any and all advice!
Old 11-12-2003, 10:39 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
The nose should be easy enough just by loosening and repositioning the nose support brackets unless the plastic is actually damaged.
The hood dent, I would stack some 2X4 chunks under the hood, line them up under the dent, cover the 2X4's with a towel, then slowly close the hood down... As the hood closes, the 2X4's will press the dent upwards. Use two hands (one on either side of the dent) to press downward and bow the curve back into the metal.
If there's not enough room to get the above done, then cover a 2X4 with a towel and use a hammer to drive the 2X4 into the bottom of the hood until the dent is gone. With that shallow of a dent, you should have no trouble just pressing it out by hand using the other method though...
Old 11-12-2003, 12:27 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
hood dents are tough to fix. A hood is a very rough environment for body filler, so it's important to get it as good as possible so that minimal amounts of filler is necessary.
Old 11-13-2003, 10:30 AM
kanuck's Avatar
Car: 1982 Trans Am
Engine: 350 Crate
Thanks bnoon!
I'll give that a try. As long as I get most of it out, it won't look so bad until a body shop gets at it.
Old 11-13-2003, 09:15 PM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
Rubber mallet with t shirt covering it (the mallet). Start off light and see how it goes then a little harder untill its done.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
Hotrodboba400
12-10-2019 07:07 PM
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
Hotrodboba400
09-02-2015 07:28 PM
SlowAZ28
09-02-2015 05:19 AM
Quick Reply: How do I fix this hood dent myself?
