L98 cam specs
Old 10-25-2003, 06:37 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
L98 cam specs
Does anyone have the stock specs for an L98 cam? I know the duration is 207-213, but what is the IVO, IVC, EVO, EVC, specs? Such as you would use to plug into desktop dyno?
Thanks.
Old 10-25-2003, 08:55 PM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
here is a screen shot of the cam specs
Old 10-25-2003, 09:56 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Or you could just go to https://www.thirdgen.org/newdesign/tech/techdb.shtml and see all the cam data you could ever want.
Old 10-25-2003, 10:07 PM
Car: 1971 Camaro
Engine: 427
Ponco@home, I tried plugging that into Desktop dyno, but it won't let me put in - numbers. What gives??
Oh,
I looked at that page first. It does not list the opening or closing times, just lift , duration, and lobe sepatation.
Old 10-25-2003, 10:15 PM
AJ_92RS's Avatar
You can't enter the IVO, IVC, EVO, EVC number anyway. All you can enter is the LCA, IC, duration (either seat-to-seat or .050") and the lift at the valve.
Enter everything that's in those specs, then use the LCA as the IC -4*. That's the average amount of advance on a SBC cam.
You can enter 116* like poncho has, but there's no guarantee the cam you'll install will have the same IC unless you check it (aka degree the cam).
Old 10-25-2003, 10:19 PM
Car: 1971 Camaro
Engine: 427
I have Dyno2000. You must enter those specs on it.
Old 10-25-2003, 10:27 PM
AJ_92RS's Avatar
So do I, and you don't have to. All I have to do is enter the specs I mentioned and it automatically calculates the timing events.
On the toolbar on the top there's a small ICON that looks like a cam. Click on it and you can enter the specs I mentioned. Then the work is done for you.
If your toolbar isn't showing then click on "Tools" then "Cam Math..."
If you want the toolbar to show, click on "View" then "Toolbar"
Old 10-25-2003, 10:31 PM
AJ_92RS's Avatar
Here's a pic of it. It says "Cam Math" with the little red line pointing to it.
Old 10-25-2003, 11:19 PM
AJ_92RS's Avatar
Did you get it figured out Johnny?
Old 10-26-2003, 08:27 AM
Car: 1971 Camaro
Engine: 427
When I go to cam math, I get the screen posted previously, however, it will not allow me to post a negative time.
Old 10-26-2003, 12:45 PM
AJ_92RS's Avatar
If you're talking about the -12.5 under IVO, Poncho didn't enter it, the calculator calculated that.
Make sure you have the "Cam Specs @" set to ".050-Lift" when you enter the other specs like duration, lift, LCA, IC, etc.
IVO (BTDC) -12.5* means the intake valve doesn't start to open until 12.5* ATDC, which is why it's expressed as a negative number BTDC. But that's where it is at .050" of lift which is why it's expressed as a negative number.
If you had the "seat-to-seat" specs, and were to enter them that way, that probably wouldn't come out to be a negative number.
I'm not trying to sound critical, but maybe you should break the "guy rules" and actually read the instructions that came with DD2000. Or maybe buy some books that tell you what those cam specs mean.
Old 10-26-2003, 08:18 PM
Car: 1971 Camaro
Engine: 427
I know what the cam specs mean. I am having a problem with entering the numbers, not cam knowledge. With the specs entered the same as in the post, and I click on 'apply', it states
" a valid IVO value is required"
Old 10-26-2003, 09:11 PM
AJ_92RS's Avatar
As I said, I wasn't trying to sound critical.
Start with a cam from the main menu, the change the specs of it.
lt500r55
09-01-2021 01:30 PM
ChaseDale3and8
09-01-2015 01:49 PM
italiano67
08-31-2015 06:04 PM
SLNTSCPE
08-22-2015 09:15 PM
anesthes
08-08-2015 09:37 PM
Quick Reply: L98 cam specs
