Which distributor gear w/GM HOT cam?
Old 10-15-2003, 02:41 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I need to know if I need to change my distributor gear when using the HOT cam. The gear I have now is just a production GM HEI gear from 1978. I know that I don't need a bronze gear because GM recommends a melonized gear. What is this melonized gear and do I have one? Please Help!
Old 10-16-2003, 11:14 AM
Parrydise7's Avatar
Car: 1985 Camaro
Engine: .040" over 350
Axle/Gears: 9-bolt with 3.45s
Check out the GM Performance Parts catalog. The distributor with the melonized cam drive (whatever the heck that is) is p/n 1104067.
I'm editing to let you know that you can also get just the melonized steel distributor gear as p/n 10456413.
Old 10-16-2003, 11:23 AM
HeavyBreathinRS's Avatar
Car: 1990 RS
FYI Melonizing is a patented process similar to nitriding in that it imparts a very hard wear resistant surface to steel, and has a low coefficient of friction.
Melonizing is different from nitriding in that the surface is porous and retains oil for lubrication for longer life.
Old 10-16-2003, 12:37 PM
GASGZLR's Avatar
Cool! I guess I am going to have to dish out the cash for a little weenie gear. Too bad I was hoping to be able to use my stock gear. I still have my distributor from the TPI days and it is the small remote coil HEI. If some how I could make that gear fit my old school distributor it would work, right? Aren't the shafts different by like .1 inches in diameter?
junkcltr
08-02-2019 11:12 PM
jklein337
09-19-2018 06:23 PM
camaro71633
09-01-2015 10:24 AM
cstrobel65
08-15-2015 10:19 AM
Quick Reply: Which distributor gear w/GM HOT cam?
