how to set timing on 89 K1500?
Old 09-01-2003, 09:40 PM
IHI
IHI's Avatar
Had a head gasket go bad, just need timing in a nut shell for this beast. 89 Chevy K1500 with 350 TBI unit. Heard I have to unplug a certain wire behind the plastic cover on firewall, then just set the timing at an idle to 0? Does this sound right or am I on the right track, also, what wire am I looking for anyways. Thanks for quick help.
IHI is offline
Old 09-02-2003, 05:55 PM
boogie's Avatar
Yea man, i would be glad to help. Remove the relay cover from the pass side firewall ( three plastic nuts) unplug the timing connector, It will be a tan wire with a black stripe. the connector will most likely be taped to the larger wire loom with electrical tape. Set timing to 0º with the connector unplugged and at an idle with the engine warm. Dont forget to reconnect it when done.
boogie is offline
Old 09-02-2003, 06:12 PM
IHI
IHI's Avatar
hey boogie, thanks for the info man, much appreciated!! Whatever happened to the good ole days when you could work on a vehicle? To old and stubborn at this point to change my ways, but guess gonna have to do something with the times a changin.
IHI is offline
Old 09-02-2003, 06:19 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i don't know about you, but i don't see much problem in just working on them. you may want to read the sticky's also.
zippy is offline
Old 09-02-2003, 08:03 PM
Vader's Avatar
Reading the "sticky" messages at the top of the boards would be a good idea.
Vader is offline
specialized
06-18-2022 09:26 AM
Vintageracer
01-10-2020 05:33 PM
midge54
12-27-2019 04:14 PM
Azrael91966669
DIY PROM
25
06-20-2017 04:04 AM
Andrew6.688
12-13-2015 10:59 AM
Quick Reply: how to set timing on 89 K1500?
