ground strap
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
ground strap
Found a braided ground strap near the passenger firewall. Where does it go? What does it do? What happens when it isnt connected? I searched and got mixed answers. Some say dont bother reattaching it, others say it can couse problems. Read it goea to the head also read it goes to manifold. Could somebody set me straight here?
Thanks,
Matt
Thanks,
Matt
I searched again. I'm gonna reconnect it reagrdless, I figure it could only do good. Can I just attach it to the bolt on the valve cover. There is no way i can reattach it in the right spot. I have centerbolt style covers. I figure putting a ring terminal on th end and slipping it under the valve cover bolt. This a problem?
Thanks,
Matt
Thanks,
Matt
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
They usually attach to the back end of the cylinder head, or on the block just above the bellhousing.
Pete
Pete
I dont think i can reach back there. Can i just put it on the bolt on the valve cover?
Thanks for the reply,
Matt
Matt
ttt
Can I reattach it to the bolt on my valve cover?
Thanks,
Matt
Thanks,
Matt
Car: "02 z-28
Engine: LS-1
Don't use the valvecover, it's not a great ground. If you have an external coil mount the wire to the base mounting bracket, or the the bracket for the EGR vacuum solenoid which is also usually there.
The egr solinoid? Whats it look like?
What about the plenum? I dont have the distributor cover piece on. Can I put it through on one of those bolts?
Thanks,
Matt
Thanks,
Matt
