Where does this ground wire go?
Old 07-16-2003, 11:52 PM
pasky's Avatar
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
If you look on the passenger side firewall there is a braided ground wire coming from the fire wall, where does the other end go to because mine is just hanging? Also, my electric fan and light gauges are not working, the fan relay and motor are brand new, I have a feeling im not getting a good ground somewhere, also my oil pressure gauge does not work, I really think this is a ground problem as all this was working previously. I need an answer asap please, thanks.
Old 07-17-2003, 02:25 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
That is a common "problem" when changing the tranny or engine. That wire gets left off the motor as its real hard to deal with whil you got a tranny on your chest trying to get some bolts started. It not a big suprise find.
Matt
Old 07-17-2003, 02:30 AM
pasky's Avatar
So where does it go and what does it do?
Old 07-17-2003, 07:26 AM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
i think it goes the the engine block. I remember seeing that wire when i pulled my engine.
you dont need to reconnect it, the engine/car already has like 5 ground points, and you technically only need 1.
5 is just like a safety net i guess.
Old 07-17-2003, 09:34 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
the braided wire from the frewall goes to the backof the head. This does need to be connected, and is something that does usualy get forgotten about durring engine swaps and usually get forgotten about. Guilty here, just not on the one, my first swap. 77 T/A, had everything in & wouldn't run right. forgot to connect the ground strap. Remeber, unlike most GM engineering, it's there for a purpose.
Glowsock
08-02-2020 07:36 PM
Jae992
08-27-2015 09:07 AM
Glowsock
08-26-2015 12:28 AM
Armored91Camaro
08-25-2015 12:01 PM
eightsixseven
08-14-2015 03:09 PM
Quick Reply: Where does this ground wire go?
