Painting bolts in engine compartment
Old 06-02-2003, 10:51 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I like to take what’s rusty in my engine compartment out to sand, prime, and paint it. Last time I did this to some bolts. I remember when tightening the bolts after the process some of the paint would come off and brown primer would show. What would be the easiest way to make it look good without the paint chipping off after using the wrench to tighten them?
Would detailing them after they have been tightened be the easiest way?
Old 06-03-2003, 12:19 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
You could wrap some masking tape around the bolt, tighten, then remove the tape.
Old 06-03-2003, 01:13 AM
joshp14's Avatar
Or if you can get to the bolt after it's been installed you could mask it off real quick and spray it real quick to touch it up.
Or find yourself a model paintbrush and spray some of the paint on a piece of paper or cardboard and touch it up with the paintbrush.
Old 06-05-2003, 12:03 AM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Im with you the tape keeps from chiping the paint off
Old 06-05-2003, 07:11 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Not if you need to put any sort of torque on it. I say take them out and either clean them up with a wire wheel, or get replacement stainless steel 12 point bolts from ARP or something
Old 06-05-2003, 07:25 AM
MCas7's Avatar
I would say to use a brush applied paint. Just hit it after you torque it down.
Frozer!!!
01-19-2024 04:55 PM
Vintageracer
01-10-2020 05:33 PM
MoJoe
Fabrication
08-19-2017 07:12 PM
Reddeath210
10-06-2015 08:20 AM
bradleydeanuhl
08-12-2015 11:48 AM
Quick Reply: Painting bolts in engine compartment
