too much power steering fluid?
Old 06-01-2003, 07:59 PM
black83z's Avatar
What happens when you put in too much power steering fluid? Everything i read (PS fluid bottle, car manual) says do not overfill. Wellll....i overfilled. I can probly siphon it out, and its not a problem now anyway because i dont have a belt on the pump, but why shouldnt you overfill it? Will it cause any serious problems? Thanks
Matt
Old 06-01-2003, 09:01 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
I over filled mine once when i had a leak. But some leaked out to bring the level back down. But i i didn't notice any problems.
It should be fine.
Old 06-01-2003, 09:10 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
I've overfilled many and had no problems. I think it's just so that you don't overflow when it's hot causing it to leak out the top and all over the block/road and maybe make a fire.
Old 06-01-2003, 09:23 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No serious problems... it spews out the extra, then it's OK after that.
Vintageracer
01-10-2020 05:33 PM
colton_carlson
03-08-2019 12:21 PM
evilstuie
04-14-2016 08:52 PM
backtothe80s
09-05-2015 12:39 AM
sailtexas186548
08-24-2015 10:11 PM
Quick Reply: too much power steering fluid?
