New ZZ4 and Stealth Ram , Running like #$%^ please help
Old 05-21-2003, 06:35 PM
1991 Z-28's Avatar
Car: 1991 z-28
Engine: zz4 350
Transmission: t-56
We set the timing at about 8 degrees. The fuel pressure is set at 44psi. This thing is pulling 12 inchs of vaccumn at idle and even my own 388 pulls 16 inchs at idle. I change the plugs on it switched out the ignition coil. I've reset the valves incase they were not set properly even though its a crate motor and you should have to. I played around with the PROM, and when i try to give it more fuel in the VE tables, it just runs terrible. The plug readings are jet white, which means its running way too lean, but it doesn't like to run any richer than it is now. The car is extremely jerky fuel if added to it in the PROM. What other suggestions to run on the checklist to get this thing going properly before nationals?
cam is 208/221 LSA 112
Attached Thumbnails New ZZ4 and Stealth Ram , Running like #$%^ please help-zshow1.jpg
Old 05-21-2003, 08:26 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Transmission: gear jammer
Axle/Gears: 4.11
Try adding a $hit load of fuel to the initial shot. Some refer to it as the "pump shot". It helped my lean condition a lot and made it easier to drive around town. Try to do a search on the prom boards. They're getting pretty good at tuning these HSR motors.
Old 05-21-2003, 08:28 PM
Free Bird's Avatar
Axle/Gears: 4.11
Is that Jeremy's (Poorboy8) car in the bottom right?
Old 05-21-2003, 08:47 PM
Steve86TA's Avatar
Car: To many to list
Yes it is.That was last year at a meet we had in So. MD.Did he get any paint on that thing yet?
Old 05-21-2003, 09:03 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: 9", 4.33:1
Is it going into closed loop? Got any scantool data (BLMs, knock counts, etc)?
Old 05-21-2003, 09:57 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Re: New ZZ4 and Stealth Ram , Running like #$%^ please help
...and when i try to give it more fuel in the VE tables, it just runs terrible...
Uhhh, it idles with 12"Hg and you want to put MORE fuel in it?!? You're going the wrong way. You need to lean out the VE table in the idle area. I'd also crank the timing up in the same area. That should get you driving so you can tune it.
Old 05-22-2003, 04:08 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
The car is running super lean, the plugs are jet white. There is alot of timing in it, so much that i was afraid it might hurt it because of how lean the car was running, so i backed it down a little. I'm going to check the firing order on it when the weather breaks, but i would assume thirdgen resource got that right, I mean 1991 Z-28 did pay a fair chunk of change for this job. then again, we all know what happens with assumptions.
Old 05-22-2003, 04:31 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
Hmm....
I really don't know anything about tuning cars with proms and all but... with these Stealth Rams and such can't you tune the car with a lap top in the car? If so then couldn't you set the base timing to 10 or 12 degrees, then alter the fuel mixture to get the most vacuum?
I would also get an air/fuel gauge....it always helps me out. If the plugs are white, then yes it's lean....but are the plugs looking like this when you let it idle for like 5 mins then pull them out? The a/f gauge would really help you out cause all you would have to do is set the a/f mix to 14 or so on the gauge and you are set, comp. controlled cars ecm's will usually make up the rest of the driving range...well stock ones anyway....shoot I better get off this post before I say something retarded.
Old 05-22-2003, 04:32 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Oh yeah...
What do you mean..." The car doesn't LIKE the fuel mixture to be any richer than it is now"
Clarify....
Old 05-22-2003, 08:33 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
When more fuel is added in the VE tables, the car runs really bad and is extremely jerky. It almost stalls at part throttle and when you crack the throttle it just flat out dies out.
Old 05-22-2003, 09:00 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Geeezz.
That's really strange. What kind of air intake/filter assembly is on it?
Old 05-22-2003, 09:28 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
Same as factory, tpi boot with y snorkel with two paper filters.
Old 05-22-2003, 11:00 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
hmmm....
i know it's a long shot, but sounds to me like you r are choking the motor, then when you richen the mixture, it richens even more rapidly because you are already at a standpoint with the amount of air entering the engine. Just a thought, but why in the heck do you have a Stealth Ram with factory intake? I don't get it. At least some K&n's and maybe a ram air setup later.
Old 05-23-2003, 02:05 AM
Kingtal0n's Avatar
Car: 240sx
Engine: whatever works
Transmission: 4l80e this year
Axle/Gears: 3.512
vacuum leaks.
that cam should pull more than that at idle. whats the idle speed? my 218/224 Pulls 15" at 800 Rpms. My 234/244 pulls 10" at 800 Rpms. if your only pulling 12" at 800 rpms somthing is wrong. it would explain the super lean looking plugs, and the jerkiness.
are you using a MAF? vacuum leaks play hell with mafs because the computer doesnt see the extra air and wants to pull fuel out.
Old 05-23-2003, 08:47 AM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
Not a single vaccumn leak, and it is Speed Density so no MAF sensor. I'm leaning towards the firing order being off since thats the one thing i haven't checked yet.
9192camaro
16
02-03-2019 12:21 AM
Azrael91966669
DIY PROM
25
06-20-2017 04:04 AM
Steve78LT
02-24-2016 12:15 AM
ASE doc
Alternative Port EFI Intakes
08-25-2015 09:14 AM
L98GTA87
08-11-2015 06:55 PM
Quick Reply: New ZZ4 and Stealth Ram , Running like #$%^ please help
