HELP!! 700R4 leaking Bad!....
Old 05-13-2003, 09:38 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
PLease help. I've got an '88 Trans Am with the LO3 and a 700R4. It's leaking tranny fluid BAD!! We put 2 bottles in tonight, and by the time I got home (about 20 miles), it was all leaked out! The RPM's surge when I'm going 70 from around 1800 to 2100 very rapidly. When it's REALLY low, i can feel it surging. We're gonna put it up on blocks tomorrow and see where it's leaking from. I hope it's just a gasket or something. Does anyone have any suggestions?? I know I'm not providing a lot of info, but I don't have much. Thanks in advance to all!
Old 05-14-2003, 02:41 AM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
could be a couple things...
You didnt hit any big rocks did ya? lol
uhm, sounds like your pan is leaking, probably gasket. also check the tailshaft, mine leaks from there ....
update the post once you check it out...
Josh
Old 05-14-2003, 06:47 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
There's a hole on the direct bottom of the Tranny cover. Directly under the torque converter. It looks like there should be a plug or something. Because the hole is round and about a centimeter wide. I'm just guessing though. Is there a plug that's supposed to be there, because it would be a good place for one. Anyone know? Thanks in advance.
Old 05-14-2003, 07:27 PM
nitrovette's Avatar
Car: 73 corvette
Engine: 2004 ls1
are you saying its leaking from the hole in the torque convertor cover? if you are then the front pump seal is most likely leaking.No plug or bolt goes in there.
Old 05-14-2003, 07:50 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
I took some pics, but I can't get them small enough to post, so I put them on my site.
http://members.cardomain.com/tamatt27
They're on the last page (page 6) at the very bottom. Sorry, and thanks!
Old 05-14-2003, 08:58 PM
nitrovette's Avatar
Car: 73 corvette
Engine: 2004 ls1
yeah that hole is supposed to be there,if its leaking out of there most likely it is the front pump seal.Pull the cover off and look up behind the convertor to see if its coming from there.
Old 05-14-2003, 09:09 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
So you're saying that a seal is broken inside the cover? So, if that's the case, what should I do about the hole in the cover? Thanks, sorry, i'm just a little confused.
Old 05-14-2003, 09:22 PM
Car: 1990 Iroc-Z
Im not sure what nitrovette is saying...(not that he's wrong)
it sounds to me like your tranny pan is an aftermarket one. Some aftermarket pans have a plug so you can drain your fluid. That is what it looks like to me. If it is just a hole on the bottom of your pan, try going to autozone and picking up a drain plug.
gl
Josh
Edited****
I jus looked at the picture...nevermind what i said above....vette is probably right. i thought the actual pan was where you had your hole.
Old 05-14-2003, 09:32 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Thanks, so is there a part number or something? Or do I just ask for a tranny cover plug for a 700R4? Thanks,
Old 05-14-2003, 09:49 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Go back and read prOject's edited post. That hole in the cover is not the problem. Take the cover off and you will see transmission fluid is not stored there. The cover is just that, a cover. I protects the torque converter from getting damaged by rocks and degris under the car. It sound like the front pump is leaking or the torque convertor itself is damaged. When you drove it home did you notice a difference in the way it felt in first gear or leaving a stop light? Anyway, it sound like the front pump to me. Take the cover off. If you are leaking fluid that bad, it should be pretty obvious what the problem is.
Old 05-14-2003, 10:01 PM
Nordbert's Avatar
Your front seal in the pump is probably blown out. Take it to a
tranny shop you trust and have it checked.
Old 05-14-2003, 10:36 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Thanks, i'll try and take it to the shop in the morning. So if it indeed the front pump seal, is that expensive to fix? And what should I do about the hole in the cover? Is that ok how it is? Or should I get a plug or something for it? Thanks
Old 05-14-2003, 10:58 PM
Car: 1990 Iroc-Z
i believe someone mentioned it is supposed to be there. probably so if something like that happens, it doesnt fill up with fluid. kinda of a warning sign. heh.
yah, their right...its jus a cover, keeping roadkill off your flywheel...
mines been off for awhile, no idea where it has gone.
Old 05-15-2003, 05:40 AM
nitrovette's Avatar
Car: 73 corvette
Engine: 2004 ls1
yes get to a tranny shop and check it out.Theyll have to pull the trans to fix it if thats what is it.
prOject-IrOc- like he said dont worry about the hole.
Old 05-15-2003, 07:25 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Damn, the guy said that if he were to pull the transmisison out, then it would be better to rebuild it and put all new seals while it's out. Since my dad ould be paying for it, due to me spending most of my money on the paint job, then it would get a mostly stock rebuild, no performance parts.
Old 05-15-2003, 07:54 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
How much was he going to charge you to rebuild the tranny? In some cases it may be better to by a new one. A local shop was going to charge me around $1200 to rebuild mine back to stock. I got a Pro-built for $1395.
Where in Bastrop do you live? I lived there for about 5 years.
Old 05-15-2003, 10:56 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
We've been to a few shops, but I think the average os about $1100 to rebuilt it. I spent all my $$$ on my paint job , so my dad's gonna have to pay for it. He saus that he's not gonna pay for ANY performance upgrades. I live south of Bastrop, towards Smithville. Thanks,
Old 05-15-2003, 11:14 PM
Car: 1990 Iroc-Z
i just got a rebuilt performance tranny from ebay. check it out...
http://cgi.ebay.com/ebaymotors/ws/eB...ory=33727&rd=1
has 1 year free replacement warranty, no questions asked.
Josh
Old 05-15-2003, 11:48 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Don't tell him you are getting performance upgrades. How much is he willing to spend on the transmission?
Old 05-17-2003, 12:36 AM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Well, he found a guy that'll rebuild it, and put some 'performance parts' in too. What performance parts should I be asking for? I was thinking about the corvette servo?
Old 05-17-2003, 01:07 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I would get the corvette servo and the Transgo Recalibration kit. I have a transgo recal kit that I bought and was going to put in my transmission but didn't get a chance to before the tranny died. I decided to buy a tranny from Pro-built that already has it installed. I sent you a PM.
Old 05-17-2003, 08:50 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Thanks. Jfreeman74, i sent ya a PM. Thanks tho. Where can I get a corvette servo? How much would one cost? Thanks,
Old 05-18-2003, 01:53 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
You can get one from www.Pro-Built.net. I'm not sure what he charges for them. I got my corvette servo off ebay for about $15.
Old 05-18-2003, 05:09 AM
Car: 1990 Iroc-Z
ill sell you a brand new one i bought over ebay, a week before my tranny went out. it jus got here 2 days ago. still in wrapper.
20 bux. i paid 35 after shipping
Old 05-18-2003, 07:54 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Thanks!, but I don't know if it would be here in time. I need to have my car back by Thursday, so I don't know if that would work out. I'll just ask the guy if he's got one. What exactly does a Corvette Servo do? Sorry, knew it's good, but forgot y
xxx3man`
09-23-2015 10:37 PM
mike_c
08-27-2015 04:32 PM
formula_novice
08-18-2015 08:48 PM
drathaar907
08-06-2015 04:20 PM
Quick Reply: HELP!! 700R4 leaking Bad!....
