How many quarts of tranny fluid r in a TH 700R4
Old 04-12-2003, 08:40 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
I just blew the seal gasket whatever? and I need to refill it thnks
Old 04-12-2003, 10:47 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
It all depends on how much you lost. With mine completely empty including the TCC... it took something like 9 quarts.... the book says tranny takes 10 pnts (5 quarts).
Best way is to pour in until you get a reading on the dip stick cold... then run in park for 10minutes or so to get the fluid through the tranny.... then add more while running the engine at it's normal temp until the dipstick says full.
Old 04-14-2003, 12:15 PM
SHAGME's Avatar
Car: 1988 IROC-Z
THNKS it was all out cause we had to take his pan down
Old 04-14-2003, 07:34 PM
If you take the pan off, fluid wont drain from the converter. So it would just be the 10pnts.
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
mfp189
09-27-2015 09:25 AM
indygene
09-26-2015 11:21 AM
Dragonsys
09-25-2015 03:51 PM
6998poncho
09-25-2015 02:56 PM
Quick Reply: How many quarts of tranny fluid r in a TH 700R4
