700r4 line pressure settings/readings
Old 03-23-2003, 01:52 AM
radiateu2's Avatar
Ok, I did a search on this and found nothing. I would like to know what the line pressure readings on a 700r4 should be in the various gears. I have the correct pressure guage but I dont know what the pressure should be set at. Any help would be appreciated.
Old 03-23-2003, 08:25 PM
radiateu2's Avatar
So,nobody knows what the line pressure should be or how to adjust the tv cable for the right line pressure with a guage? Come on guys how about some help here.
Old 03-23-2003, 11:13 PM
KevinP92Z's Avatar
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
700r4 line pressure (psi)
My ATSG book shows this chart:
Attached Thumbnails 700r4 line pressure settings/readings-700r4ps1.jpg
Old 03-23-2003, 11:24 PM
radiateu2's Avatar
Thanks Kevin now I just have to figure out which model I have and I am all set. I think!!!!!!!
Old 03-24-2003, 12:03 AM
KevinP92Z's Avatar
700R4 model identification
On the right (passenger side) of the pan rail racing to the outside of the car, you'll see a flat spot that has the number. The first digit is the year of the tranny, the next two characters are the model number.
Old 03-24-2003, 12:05 AM
radiateu2's Avatar
Thanks Kevin, I know how to set the tv on an AOD but not a 700r4. Is there a method to it or do you use the guage. How did you set yours up?
jklein337
09-19-2018 06:23 PM
Andrew6.688
12-13-2015 10:59 AM
g.l.mos
08-22-2015 12:02 AM
wayshegoes
08-17-2015 12:00 PM
Kaweh
08-09-2015 02:54 PM
Quick Reply: 700r4 line pressure settings/readings
