Wells MAF sensor
Old 03-05-2003, 03:21 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Transmission: 6 Speed
Axle/Gears: 9" 4.11 Truetrac
Wells MAF sensor
where can i get the Wells MAF sensor and how much CFM does it flow vs stock,
Old 03-05-2003, 03:48 PM
Jza
Jza's Avatar
AutoZone had em.
Old 03-05-2003, 08:11 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
There was a guy on ebay that was selling them pretty cheap. He had a bunch of them. They flow 750cfm - the same as a fully modified stock MAF.
-Schultzy
Old 03-05-2003, 09:37 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Do a search. You'll find the address for a place in buffalo. That's where most of us bought them. They're cheap, and they shipped it right away. I had mine within a couple days.
Old 03-06-2003, 12:17 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
hey Jim, u probably recognize me from iroczone. you think that aftermarket maf is going to help me out any considering i have a stock throttle body. dont wanna waste money on useless parts
Old 03-06-2003, 08:14 AM
Jim85IROC's Avatar
Not unless your stock one is malfunctioning. That's the only reason to replace it. The Wells flows more air than stock, but the computer is only capable of recognizing a specific airflow level regardless of how much the sensor itself can flow.
Old 03-06-2003, 09:01 AM
formul8!!'s Avatar
Car: 2004 GTO
Does the ECM recognize this MAF from the stock Bosch? Is it a direct plug in and go?
Old 03-06-2003, 09:45 AM
Jza
Jza's Avatar
Yes. It's not really a "performance upgrade" per se. It's simply a better designed replacement part. It's supposed to have a built in circuit that emulates a burn-off cycle, so that you don't get an error code for the burn-off (the Wells sensor doesn't go through a burn-off).
Old 03-06-2003, 10:27 AM
doc
doc's Avatar
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I just did that search and came up with:
www.wdautoparts.com
You are looking for part number SU-145.
Old 03-06-2003, 05:09 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
my other idea was just swaping over to MAP, but only if theres a performance benefit from it. stock heads and cam.
Old 03-07-2003, 08:54 AM
Jza
Jza's Avatar
No performance gain switching to MAP.
That's basically like pouring your shotglass drink into a bigger glass. It'll hold more, but you've still got the same amount of drink.
Old 03-07-2003, 11:04 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
The Source for the WELLS Maf P/N SU-145 is:
WORLD DISCOUNT AUTO PARTS
1635 ELMWOOD AVE
BUFFALO, NY 14207
1-800-288-6728
PRICE $156.95 + 6.50 S/H
Old 03-07-2003, 11:34 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
ill keep the wells su 145 unit in mind if my current MAF ****s the bed on me
SiCkRs
Members Camaros
32
07-01-2018 04:53 AM
Warlocksirix
09-03-2015 12:26 PM
Logan Bryant
08-27-2015 11:52 AM
DiabolicalRS
08-26-2015 07:35 AM
Bert87
08-23-2015 03:50 PM
Quick Reply: Wells MAF sensor
