distributor gears???????????
Old 02-25-2003, 09:08 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Ok, I am changing from TPI to carb. I will still be running the stock L98 cam. Do I have to get a special gear for the non-computer controled dist to go with the stock roller cam?
Is it just a standard gear on the factory dist on not???????
Old 02-25-2003, 09:35 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No need to change the gear.
Old 02-25-2003, 09:52 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Thanks, I had seen the bronze gears for the roller cam setup, but It is just for after market or certain roller cams. Is that right?
Glad to hear I dont have to change it for just the stock cam. What about something like the comp xe282hr cam?
Old 02-26-2003, 12:29 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The factory used what they call a "melonized" gear on distributors intended for factory roller cams. It has a surface treatment that non-roller cam distributor gears don't get. But, the melonized gear will work with non-roller cams as well.
Aftermarket roller cams in days of yore were made from billet stock. It was hard, and would wear out "regular" distributor gears. So, bronze was used.
Old 02-28-2003, 07:45 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
thanks for the replys guys. I will be changing to the comp xe282hr or maybe larger cam later on. I found out from comp that the stock gear on the non-computer controled dist will be fine also.
like I said thanks guys.
jklein337
09-19-2018 06:23 PM
beastin91rs
10-09-2015 07:38 AM
mddaniel
09-08-2015 05:16 PM
86IROC112
08-17-2015 07:57 PM
eightsixseven
08-14-2015 03:09 PM
Quick Reply: distributor gears???????????
