TPI MAP sensor VS LT1 MAP sensor
Old 12-05-2002, 06:35 PM
S10Wildside's Avatar
Is the TPI MAP sensor the same as the LT1 MAP sensor? I have several LT1 MAP sensors and am converting from MAF to speed density. Hopefully I can just use the LT1 MAP sensor. Anyone know for sure?
Old 12-05-2002, 11:22 PM
GhoSSt's Avatar
Same Same. Some have little plastic keyways. But they are the same internally.
Old 12-05-2002, 11:29 PM
Bort62's Avatar
That woulda Been my guess, haha.
Gotta love the General.
If it was a ford, better know wich Month The System your working on was built in
Old 12-06-2002, 04:55 AM
I've heard that some MAP sensors are different...such as the Syclone and Typhoon. That's why I asked. The MAP sensor on my 1997 Sonoma looks exactly like the LT1 MAP sensor I have. I don't plan on using that one, but it was an observation.
Old 12-06-2002, 11:59 AM
Morley's Avatar
Originally posted by S10Wildside
I've heard that some MAP sensors are different...such as the Syclone and Typhoon. .
Thats because they were forced air induction and used a 2 bar map.
Old 03-17-2010, 12:17 PM
310cid's Avatar
Car: 92 camaro
Engine: 406
Re: TPI MAP sensor VS LT1 MAP sensor
so can i run a lt1 map on a tpi with out problems or do i have to get a certain one
Old 03-17-2010, 01:19 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
The looks of them were nearly identical of most MAP sensors from V6 up to the LT1, the difference (other than how the map sensor went into the intake with the gasket on the LT1) is mainly the plug. There were minor changes with the "alignment" tab inside. I can't help you with TPI to LT1 MAP sensors, but make sure that the plug is actually identical and that it plugs in, because i tried a few map sensors out of junkyard cars and couldn't get one to work mearly because the tab inside of the sensor didn't line up with the plug, and i didn't know enough about them of whether i could destroy the tab to make it plug in. Hope this helps a little.
9192camaro
16
02-03-2019 12:21 AM
Caspar
06-19-2016 11:19 PM
91REDZ28VERT
08-18-2015 10:16 PM
Sanjay
08-12-2015 03:41 PM
squiggy2
08-09-2015 09:30 PM
Quick Reply: TPI MAP sensor VS LT1 MAP sensor
