Which ECM 1993 Caprice Cop Car?
Old 11-04-2002, 06:36 PM
EagleMark's Avatar
I just got a 1993 Chevy Caprice X Cop Car 5.7 liter TBI and was wondering what ECM it had?
Also would a 454 TBI help on the small block?
What's the difference between the 305 and 350 TBI? (for another project)
Old 11-04-2002, 09:56 PM
JPrevost's Avatar
Car: 91 Red Sled
If it's TBI then it's the 8746 ecm and the ANLU eprom.
Old 11-05-2002, 12:25 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
In 1992 the Caprice went to a 161xxxxx number but its a similar ECM to the 1228746. I don't know if GM just changed the number or if it's completely different like the trucks when they changed in 92 as well.
Old 11-06-2002, 09:20 AM
TBI305Camaro's Avatar
I dont know about the computer but I have that motor. you wouldnt happen to know what the size of the knock sensor hole is do you?
Old 11-06-2002, 11:06 AM
EagleMark's Avatar
Haven't had time to look at the ECM let alone the knock sensor hole.
I thought it would be a clear cut answer here but there seems to be some controversy as to which ECM it is so I will have to dig in and take a look.
Old 11-06-2002, 12:42 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
I believe the 93 Caprice uses this: 16136965
Different Tunercat definition file ($62 vs 8746 which is $61)
Old 11-06-2002, 02:04 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
Yes, the 93 caprices use that ecm, which has a different definition file from the 8746. I just got a new def. file from tunercat, which enables the manual/auto logic, so you can run the cop car calibration with a manual now.......
Old 11-06-2002, 02:12 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
What's the difference? Lack of a 4th gear switch and no TCC lockup controls?
Old 11-06-2002, 02:51 PM
JPrevost's Avatar
Car: 91 Red Sled
There is no difference except for what you just said. I just compared the tables of a stick vs auto TBI eprom and saw that a few constants were changed along with table info. They both had TCC controls AND shift light parameters but only one output.
I didn't know 93 was any different than 92, learned something new. Why would GM change if they already knew they had the Lt1 as the next powerplant for the caprice? GM is crazy like that, too many darn calibrations hardwired to the C3 and C4 ecms!
Old 11-06-2002, 02:54 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Well...it may be that 91-93 Caprices (TBI B-Bodies) used the 6965 and the only Caprices that got the 8746 were the 89-90. That would at least make more sense.
Old 11-06-2002, 04:53 PM
EagleMark's Avatar
Kevin I tried your link
http://kmoore.phzero.net/car/
Not working?
Old 11-06-2002, 05:08 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Sorry about that, my webserver took a dump. Everything's fine now. Thanks for letting me know.
midge54
09-02-2020 07:13 PM
midge54
12-27-2019 04:14 PM
camaro71633
09-01-2015 10:24 AM
matthew911
08-12-2015 09:38 AM
djmarch
08-10-2015 08:42 AM
Quick Reply: Which ECM 1993 Caprice Cop Car?
