Does any1 else have the Flowmaster 80 Series on an L98????
Old 09-13-2000, 10:24 PM
IROC-ZTWENTYGR8
Guest
Posts: n/a
How does it sound, how many chambers does it have, and whats the difference between the 80 and 40 Series????
Looking for:
87 IROC-Z L98
84 Trans Am H.O.
Old 09-13-2000, 11:42 PM
MrJ
MrJ's Avatar
My friend has one on his 87 IROC w/ an L98. The 80 series mufflers are 3 chamber, the 40 series are 2 chamber. His car has that metallic, tinny sound that make it sound as if it were coughing up a lung, but that's mostly because he has a gutted cat. It would probably sound OK with a cat on there. The 40 series are louder and deeper sounding than the 80 series. When most people say they have a 'Flowmaster muffler' on their thirdgen, an 80 series dual outlet muffler is usually what they have. IMO, a 3 chamber muffler with a stock, small intermediate pipe sounds crappy, and terrible with a gutted cat.
91 Trans Am WS6
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
supposed 'peanut cammed' car (yeah, right)
MoreMoodThatMod
Old 09-17-2000, 02:07 PM
IROC-ZTWENTYGR8
Guest
Posts: n/a
Are u sure it is 3 chamber?????????????
Looking for:
87 IROC-Z L98
84 TRANS AM H.O.
Old 09-17-2000, 06:00 PM
Hunter Motorsports's Avatar
Car: Camaro Z28 1LE R7U
Engine: 5.0 TPI
Transmission: G-Force Dog-Ring T5
The 80 series crossflow Flowmaster is one of the loudest mufflers Flowmaster makes. The 40 series is about the same in loudness levels but the tone is a bit different. I have the 80 series (P.N. 43083) on my car and with no converter it is quite loud. Once I put the headers on I figure I will have to change my muffler for the noise to be tolerable. A 40 series Delta Flow is quiter, especially in the interior of the car but would still have considerable "bark" outside the car. If in doubt call the Flowmaster technical assistance line. They are very knowledgable and helpfull and will help find the muffler that is best for you and your car. The tech line number is 1-800-544-4761
P.S. The 80 series is NOT a 3-chamber. It is a unique design exclusive to the 80 series crossflow muffler. The 40 series is a single in single out configuration.
Karl Hunter
Hunter Motorsports
Vancouver, B.C. CANADA
[This message has been edited by Hunter Motorsports (edited September 17, 2000).]
Old 09-17-2000, 07:39 PM
IROC-ZTWENTYGR8
Guest
Posts: n/a
Wow!! Thanks for all that information, but how many chambers is it??
Looking for:
87 IROC-Z L98
84 TRANS AM H.O.
Old 09-21-2000, 01:38 AM
Engine: 5.0 TPI
Well The Rock says: "IT DOES'NT MATTER HOW MANY CHAMBERS IT HAS!!!"
Actually it really does not matter. Flowmaster has abandoned the method of identifying their mufflers as 2 or 3 or however many chambers. In reality if you look at the design of the 50 series (formerly known as the 3-chamber) there are 4 major sections or "chambers" and they have internal deflectors and baffels that seperate them. The 30 series also has 4 major sections, but the design is different, so the sound and the way the muffler works is different.
Anyway, the 40 series was the 2-chamber, the 50 series was the 3-chamber, some of the flowmaster race mufflers are still identified as one or two or three chamber and the 80 series crossflow is completely different from the 40 and 50 series so telling you how many chambers it has does'nt do you any good.
Call flowmaster or visit www.flowmastermufflers.com there you will find the answers.
Karl Hunter
Hunter Motorsports
Old 09-21-2000, 11:56 AM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
I have the 80 series on my L98 GTA and with no cat and 3" straight pipe it is very loud!! At normal idle speeds, in other words normal driving around town, the sound is sometimes questionable as to whether I like it or not?? But at WOT it sounds loud, mean, and powerful. And what a difference it made in throttle response, especially with the cat gone! Good luck.
88 GTA
L98 350
700R4
3:27 axle
MODS,
Edelbrock TES headers, 3" straight pipe, Flowmaster 80 series, K&N filter, Accel 8.8mm wires, Bosch Platinum plugs, Wells cap and rotor button, Wells ignition module, MAF screens removed, Hypertech TB air foil, Thermomaster stage II chip, 180* Powerstat, Hypertech cool fan switch, B&M shift kit, B&M power clutch pack, B&M servo, GM fuel filter
Old 09-21-2000, 12:17 PM
IROC-ZTWENTYGR8
Guest
Posts: n/a
88 I heard putting a High-Flow converter on will make it sound better, I don't know how, just what I heard, not what I know.
When I get the IROC 350, I want it to be loud and powerful sounding at all times, idle, WOT, everything.
Looking for:
87 IROC-Z L98
84 TRANS AM H.O.
[This message has been edited by IROC-ZTWENTYGR8 (edited September 21, 2000).]
Old 09-21-2000, 05:31 PM
nicksL98's Avatar
OK.. here is my sugestion.. why dont you guys list the PART NUMBER YOU HAVE!!!! The one on my 91 is the 42583. It has the 2.5 in and dual 2.5 out. Stock cats,,,sounds good ..little louder than my gm muffler from 2 yrs ago. It sounds great when you get on it and isnt obnoxious like most flowmasters, suprisingly. And YES gutting the cat wil make it a lot louder and improve the sound if that is the direction you would like to go. Just my opinion.
Old 09-22-2000, 12:09 AM
Engine: 5.0 TPI
I have the 43083 on my car. The only differene between the 42583 and the 43083 is the size if the inlet pipe diameter. 42583 = 2.5" 43083 = 3" Both mufflers have dual 2.5" outlets on opposite sides and they are internaly identical.
Karl Hunter
Hunter Motorsports
Hotrodboba400
12-10-2019 07:07 PM
FormulasOnly
07-23-2018 08:47 AM
92camaro350cci
10-14-2015 09:29 AM
Night rider327
10-09-2015 09:25 AM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Does any1 else have the Flowmaster 80 Series on an L98????
