really quick, is midas open sundays?
Old 08-24-2002, 11:16 PM
primer84z's Avatar
i need to know if midas is open sundays. i want to get new struts/balljoints/ and basically any front end suspension parts replaced as well as new shocks in the back. thanks.
Old 08-24-2002, 11:19 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
if i remember i dont think they are, and thats alot of work for for a shop on a sunday. Your best bet would be to go out to an autoparts store and buy the parts yourself (if they have all of them) and do all the work yourself. The ive done the shocks and struts myslef and they arnt that bad to install. Youll need to get an alignment afterwards, of coarse. Hoping to do some of the steering linkages tommorow .
Old 08-24-2002, 11:22 PM
primer84z's Avatar
i was going to do the shocks my self but i couldnt even get the carpet up in the back to unbolt them. my car hates me.
Old 08-24-2002, 11:24 PM
Car: 88 Camaro SC
Engine: SFI'd 350
woah, lol... it wont come up??? I think you have to take the seats out in back (lower cushins) see if that helps.
Old 08-24-2002, 11:29 PM
primer84z's Avatar
how do i get the seats out? a local speed shop said they would do the shocks for 50 bucks and im considering that if i cant get it done tomorrow. how would i get at taking them out? just put the rear end on jack stands?
Old 08-24-2002, 11:38 PM
Car: 88 Camaro SC
Engine: SFI'd 350
alright... the rear seats,i beleive, have two 12 mm metric bolts at their base holding a metal loop down. Undo the two bolts and pull the cushions out. The carpet is vecroed to the seats, or should be, you should now be able to pull back the carpet.
Old 08-24-2002, 11:39 PM
Car: 88 Camaro SC
Engine: SFI'd 350
and 50 dollars is too much... i just finished putting in a cheapo set of gabriels this morning and it only took me like 45 mins or so.
db057
04-28-2019 07:45 AM
Twin_Turbo
03-14-2016 10:10 PM
Nick McCardle
09-10-2015 08:36 PM
Vassago
Convertibles
09-04-2015 09:37 PM
Quick Reply: really quick, is midas open sundays?
