Safe to bake headers in the kitchen?
Old 08-11-2002, 02:47 PM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
I just sprayed my new headers with some high temp paint. Now I need to bake them before they go on the car Tuesday. I wont die from the fumes or poison the next meal out of the oven will I? Just nned to know because I heard you CANT bake powdercoating in the oven you cook in. Thanks!!
Old 08-11-2002, 09:30 PM
EvilCartman's Avatar
Car: '82 Z28
I wouldn't do any sort of paint baking in an oven that will be used for cooking food. That's just me though.
Old 08-11-2002, 09:49 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Open the windows and vacate the house for a little while. If not, I doubt I can make it to your funeral. I hear it's not good for you.
Old 08-12-2002, 12:40 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
I sprayed the 1200* **** on my hedman Y pipe i just got, as soon as i fired my car up it started cooking the paint on the Y pipe. i honestly dont know how long that paint will hold up.
Old 08-12-2002, 12:57 AM
Hg
Hg's Avatar
Car: '87 Z
Engine: 355 in the works
Ok, first you have to take off the black paint they ship them with(just wanted to make sure you knew this). I was thinking about this, and I also don't have an oven to 'bake' them in. I was thinking that you could hit them with a heat gun for awhile. That might help.... what do you guys think?
Old 08-12-2002, 01:07 AM
Sciguyjim's Avatar
Whenever I use my gas oven or toaster-oven for things other than food I always heat them as hot as I can get them for a while after I'm finished. This makes sure there are no chemicals sticking around on the walls inside that can condense on the food I put in later. I've never had a problem doing this.
Old 08-13-2002, 03:22 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
I baked mine in the oven after mom left for work, hehehehehee, just do one, then let it cool, dont touch it with oven mitt's while still hot, you'll mess up the paint, someone on here bought that set I had so im not sure how the paint held, up, maybe they'll respond...
Old 08-14-2002, 10:22 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
..and how did the oven baked goods taste after that day? :lala:
Old 09-30-2002, 09:17 PM
84_CamaroBC's Avatar
I will be getting a set of hedman hedders, and i know they will rust out pretty quick around here (rain and snow), so I was wondering if anyone had tried that HT Silicone Coating from DEI (I saw it in the summit catalog). would it have to be baked on too?
Old 09-30-2002, 09:46 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you are going to waste your time (and money) baking rattle can crap in the oven only to watch it fail on your car shortly after, might I recommend spending $20 on a bottle of Cermakrome, or any other of the Techline ( www.techlincoatings.com ) protective "paints". Cermakrome is basically the same stuff JetHot uses w/o the cost part involved though. Cermakrome is slighly more labor intensive than just using a rattle-can though. Techlines other coatings do not require baking.
The black paint headers come paint with must be removed before you put any type of high temp paint on if you expect at least mediocre results from high-temp rattle can stuff. The black paint is just cheap (basically Wal-Mart $o.98 paint) semiglass black painted on to preserve the headers from rusting as they sit in the warehouse.
Unpolished Cermakrome (top), scuffed & semi polished cermakrome (bottom)
Old 10-01-2002, 08:30 AM
Sciguyjim's Avatar
I'm not familiar with DEI HT silicone coating, but unless it says specifically that it can take the extreme exhaust temps, don't bother with it. Silicones are only good to about half of the exhaust line's temps, about 300° C (572° F). They start to decompose and release toxic fumes beyond that temp. I've never heard of any silicone product that could take much higher temps.
Old 10-01-2002, 11:34 AM
zupmanZ28's Avatar
Car: 86' Z28
i just coated my headers with POR-20 from Eastwood and baked them in my oven. Like said above, just make sure you put the oven on self clean for a couple hours after your done, it gets anything that might be left in there out....
Old 10-01-2002, 02:29 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
Its alwasay bestus tpo get baqked in teh kitchen thats wherethe foood is
Old 10-01-2002, 02:57 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
I baked a set of stock manifolds, an intake and 2 sets of headers in my oven... I'm not dead yet...
I use a rattle can ceramic high heat paint (1200*)
I installed the manifolds onto my friends S10 V8 and iafter 3months, still look great.
I suggest you sandblast your headers before painting them.. I couldn't do a decent job with my first set of headers and the paint did not last in the corners where I couldn't reach by hand.
btw, if you have your intake off for whatever reason, paint that thing up!! sandblast it and paint it and it will look like those $500 polished intakes
Old 10-01-2002, 03:01 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
Surprisingly also, none of the pieces I've baked in the oven produced any smoke and hardly any fumes. I'm highly sensitive to fumes, smoke and dust and I wasn't bother at all by them, unless I stood right beside the oven.
sailtexas186548
02-17-2017 03:07 PM
redformula88
10-14-2015 06:08 PM
86CamaroDan
09-29-2015 10:08 PM
Chad Speier
09-24-2015 12:32 PM
hdis2002
09-08-2015 02:52 PM
Quick Reply: Safe to bake headers in the kitchen?
