how to know when throttle pos. sensor is bad...
Old 08-03-2002, 01:26 PM
InTeRcEpToR5.7l's Avatar
how do you know when your throttle position sensor is bad on a tbi? i think mine may be bad, thats what everyone says it may be... thanx
Old 08-03-2002, 03:37 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
The TPS tells the computer where the gas petal is so it can give the right amount of fuel. Does your car cut out? WHen you change the position of the pedal does it come back? From what I have heard it works by a voltage. Not sure how to check it, or how much it puts out.
someone please help me out..
Old 08-03-2002, 03:43 PM
88Bravo's Avatar
At a pedal position does your car cut out? Any? The TPS car develope dead spots. Or it will not start at all. Even at start up if it doesn't unless you give it a little gas, that could also be the TPS.
Old 08-04-2002, 09:59 AM
Snowdog 91 Formula's Avatar
Dead Spots
You will also get dead spots in your acceleration....
You push your foot on the pedal, and partway down you may experience your engine cutting out, or huge hesistation at some point. Not very much fun.
Old 08-04-2002, 05:36 PM
EXACTLY!
Old 08-04-2002, 11:33 PM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
Also, the car will "surge" when it's sitting at idle like at a light. It's not very fun to have the brake lightly pressed and have the car lunge forward almost rear ending the person in front of you.
Old 08-06-2002, 10:19 AM
seriosly i know what you mean, well mine idles too low too and dies sometimes, its been noooo fun to drive so i havent moved it in liek a week....just cuz im poor and cant aford my tps yet...
Old 08-07-2002, 07:29 PM
BPA
BPA's Avatar
it sences the throttle angle by voltage hence throttle position sensor.(tps) u can check the voltage by probing the conector and using a volt meter.I dont remeber correct voltage of the top of my head , is it .45 someone will know im to lazy to go look.make sure the voltage changes acording to the trottle angle of the trottle blade.
Old 08-09-2002, 09:55 AM
Fongolio's Avatar
To test put volt meter probes into connecton on tps. In the closed position you should see .56 volts +/- .07 volts. In the wide open throttle position you should see a reading above 4 volts. In between should be smooth rise to 4 volts with no dead spots. Do the test with the ignition on but the engine off. Hope this helps.
Old 08-11-2002, 01:03 AM
RHAFER's Avatar
My 91 RS Kept giving me a 22 trouble code, and when the Service engine soon light would come on, it would try to take off (usually through a red light!) the TPS Fixed the problem
Old 08-11-2002, 08:30 AM
RS91's Avatar
SES alway comming on and car runs realy rough. TPS solved all of that. Now I'm saving more gas....
Old 08-11-2002, 09:52 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Whoa! check it out! Two guys with Taz as their avatar that both replaced their TPS and it fixed both their problems! CRAZY! Maybe it's a sign.......
Old 08-11-2002, 10:59 PM
TPS issues
I had BOOKOO problems with my TPS on my NEW Holley. I kept fiddling and fiddling with it, nothing worked right. I had to replace it and everything worked right.
Just letting you guys know even if a TPS is new, doesn't mean it's not the problem.
FormulasOnly
09-10-2015 09:07 PM
Randomtask2
09-07-2015 05:06 PM
Ironhead38
09-07-2015 02:26 PM
Eric-86sc
09-07-2015 02:10 PM
Kenwood
09-04-2015 05:50 PM
Quick Reply: how to know when throttle pos. sensor is bad...
