HSR Hood clearance - Solving by lowering motor mounts?
Old 07-18-2002, 03:08 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Does anyone think it is reasonably possible to drop the motor mounts about 1/4" or so? One could do this by filling and redrilling or by ovalizing and welding in a washer inside.
I realize that as you move down, you're also moving inward due to the slope of the kmember. You would have to keep the lowering to a minimum so the clamshells will still line up.
This is I am trying my best to retain the stock formy hood, and I REALLY dont want to dent the supporting interior nor remove the heat shield. Anyone have any experience doing this or forsee any problems? There is over a 9/16" of clearance from pan to kmember. Thanks.
Old 07-18-2002, 04:42 PM
e-man's Avatar
Car: 89 formula
Engine: 383
I dont think that 9/16 is enough measure the space from the hood support to the shell you need most if not all that space.I have a 89 formula with the stealth ram I cut the brace out under the hood right above the manifold and the stock hood closes.Its a close fit and there are no dents in the hood!
Old 07-19-2002, 02:00 PM
JMatlock88's Avatar
Car: 1991 Formula
I'm not wanting to cut up my hood. :nono: I will buy an aftermarket one before I butcher it up....just trying to find another way to remain stock outside! Any other suggestions/comments welcome. Thanks for the reply
Old 07-19-2002, 06:40 PM
Guest
Guest
Posts: n/a
I dont have one so I cant really comment accurately, but maybe its possible to cut the top of the base and realign the holes and stuff and lower it a little that way? It wouldnt be cheap, but would work. I'm sure cutting the fins would work too, if they are higher than both the TB and plenum.
Old 07-19-2002, 09:07 PM
JMatlock88's Avatar
Car: 1991 Formula
Great input madmax! I think where the problem resides; however, is the slope of the hood is lowest at the front (the throttle body and front of the intake make contact I THINK) I'm a bit timid to slope or alter the base because that in itself would be changing the characteristics of the intake runners themselves. The fins are a good idea...I really need to put it on a lift to see what is making contact. I have a buddy who would mill the fins off for a fair price. Keep em coming. How to do the roadrace guys lower the motors in our cars? Specialty kmember?
Old 07-19-2002, 09:44 PM
Guest
Guest
Posts: n/a
That could be one way. Keep in mind if you do that, you are changing the driveshaft angle and you'll want to address that issue.
Another idea along the lines of modifying the plenum, a plate or mill the TB mounting area to change the TB angle to a downward direction.
Old 07-20-2002, 06:47 AM
e-man's Avatar
Car: 89 formula
Engine: 383
The top two bolts that hold the T-body is what hits the hood,and if you lower the top of the base the T-body cable linkage will hit the fuel rail.
Old 07-20-2002, 10:33 AM
ede
ede's Avatar
not sure what all would be effected by doing this, but if i were doing it, and i wanted a good structurally sound job here's how i'd do it. cut a hole where the mount goes ,box it in with 1x1x1/8 angle relocate the mounting flang of the bottom shell mount up on the body of it, use angle again. drill bolts holes as required and bolt it up. this would allow part of the calm shell to be inside the k member.
Old 07-20-2002, 11:00 PM
JMatlock88's Avatar
Car: 1991 Formula
I think my whole TB hits the hood...the Lingenfelter housing is huge. :-(
The fulcrum (the trans mount) is at the very back, so I dont see the driveshaft angle changing much with just a quarter inch or so drop of the motor. I think dropping the mounts this much would be very similar to old sagging factory mounts.
Ede's idea is great about setting the mounts in deeper in the k-member. It wouldnt be able to be sunk an inch because the long bolt that goes through the mounts still needs to be accessable, but a 1/4 inch motor mount drop would definetly best be done this way. It would still retain the width perfectly.
Frozer!!!
01-19-2024 04:55 PM
Wesly_66
08-26-2015 09:55 PM
ASE doc
Alternative Port EFI Intakes
08-25-2015 09:14 AM
Elliswon
08-10-2015 12:33 PM
NBrehm
08-05-2015 07:57 PM
Quick Reply: HSR Hood clearance - Solving by lowering motor mounts?
