How many amps does a typical small block starter draw??
Old 07-16-2002, 07:56 PM
CamaroX84's Avatar
I need to know for my demo derby car, since I will be using a push button starter, and I need to know how many amps the switch has to handle. 72 Buick LeSabre with a Buick 350 by the way. Thanks.
Old 07-17-2002, 06:42 AM
Odyssey's Avatar
Well I think you need to worry about how much the starter solenoid draws not the start itself. If the steering column start switch can handle it, I image you will need a small 10-20 AMP switch. You gotta remember this switch only sees those amps for a few seconds while the starter is turning over, so it's not like you have to get a big honking switch or anything
theshackle
03-05-2017 06:37 PM
Mickeyruder
09-02-2015 02:45 PM
Ducati900ss
09-02-2015 09:05 AM
camaro71633
09-01-2015 10:24 AM
BlackphantomZ28
08-22-2015 01:00 PM
Quick Reply: How many amps does a typical small block starter draw??
