What is a good brand of header
Old 07-10-2002, 12:41 PM
psycomaross's Avatar
What is a good brand of header as far as cost, power, installing ease etc?
I want a header size that will work well on a TBI 305, but won't hurt a SC 383 if at all possible.
and what is a good Y pipe to go with them?
I plan on having Headers to 3" Y-pipe into 3" cat and then a flowmaster American thunder cat back
Old 07-10-2002, 05:03 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
there is no way any single exhaust setup will support a super charged 383 setup. if i were you, i would get a hooker smog legal super comp shorty setup that comes with Y pipe for a good price, then invest in some longtube headers later on down the road if you ever get a sc 383 built.
Old 07-11-2002, 05:08 PM
gtabadboy's Avatar
I got the long super comp hooker headers and wish i never did. They were a pain to get in. Took about 6 hours and then I had to pay about 300 bux for a crappy pipe to connect them to my exhaust. Now the pipe is 2.5" from the headers then 2" to clear the ground then back to 2.5" to my cat. Dont make my mistake unless your car is not really a street car. Every bump hits the headers if I dont slow down. Get the short ones and save time and money.
Old 07-15-2002, 12:27 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Do a search on the exhaust board, this topic comes up every day.
Second, please change your signature.
Old 07-15-2002, 11:14 PM
xaivior's Avatar
Car: Camaro
Transmission: th-350
Axle/Gears: 3.73 welded
HEDMAN HEDDERS!!
nuff said
Old 07-15-2002, 11:18 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
Hooker, Hedman, SLP those guys have good headers
Old 07-18-2002, 10:43 PM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
Get the hedman t.e.m.s headers for 82-92 f-bodies. They are smog legal shortie style headers 1-5/8" primaries and they come with a ypipe for a single cat for about 309.00 bucks. I put them in with my motor out and they were no problem at all. look for them in the jegs catalog.
Old 07-19-2002, 03:33 AM
RS91's Avatar
Edelbrock TES Headers should be fine for your car.... plus it was easy install ..
Old 07-22-2002, 05:12 PM
Brian'sIROC's Avatar
I also run the Edelbrock TES. Good price, nice fit, good quality.
100th post!
Old 07-23-2002, 01:11 AM
RaCeCaRdRiVa's Avatar
Car: 1986 IROC
Engine: 350 H.O. Crate w/TPI
Transmission: Automatic (700R4)
I installed Edelbrock's TES header system on my 1986 IROC! They came complete with air injection hookups, oxygen sensor hookup, and y pipe for just over $300. I ordered through Summit. The shipping was free and my headers arrived within 3 days. There's also no welding or cutting required to install Edelbrock's TES system. I'd recommend them to anybody. Summit and Edelbrock kick a$$!
Old 07-29-2002, 12:08 AM
ZRated85355's Avatar
Hedman Headers. they fit good and you can change sparkplugs with them on. Also they dont burn your wires up like cheep headers. You can get a set for around a hundred bucks.
Old 07-29-2002, 12:20 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
I went with hooker shorty headers, they come with a y-pipe and go for about $365 alittle pain to install, cause of the air tubes, but installed without having to mod anything. A good bolt-on, but heres the thing, if you get any headers you need to get them Jet-hot coated, Cause if not they will rust, and look like manifolds. Jet hot is easy to maintain, and keeps the temps down in your engine bay, it also protects your headers. Alittle more expensive but well worth it.
Old 07-30-2002, 12:22 PM
chevy power's Avatar
i have the hooker long tube headers in now. they were the worst header install i have ever seen! it litterally took 5 hours or more ( i gave up the first night, had to finish it couple days later) . if u can't put ur car on a lift to make it easier to put them up in there from underneath, ur screwed. it was a major pain to get em in, now i have problems w/ spark plug wires fitting w/ out them hitting the header tubes. just last night the headers burned through the positive battery cable to the starter and i had a engine fire. so screw installing them yourself. wire routing is a nightmare.
but don't get me wrong this is the most HP gain i have ever seen in aftermarket headers. hooker is definetly the best for performance but as far as installation it was horrible.
Old 07-30-2002, 10:35 PM
383LT1intake's Avatar
Car: 92 camaro
Engine: 383 stroker
Transmission: probuilt 700r4
yeah i ve got the hooker long tubes and they are a pain in the *** once there r in the worst is the back tube on drivers side ive dimpled it and still cant get enough clearence so i carry extra spark plug wires i have a thermal boot on it and that wire will last me about a month before it burns through with out thermal boot it last maybe a day only reason i bought these header is to match my mufflex y pipe and 4" exhaust they r a pain but they r nice headers lol later
Old 07-31-2002, 12:48 AM
Kevin91Z's Avatar
Edelcrock headers would be the worst thing for a supercharged 383 engine. Right after stock manifolds.
Old 07-31-2002, 03:41 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I've replaced my Edelbrock with SLP. Much better! SLP has much higher quality than edelbrock and they looks nices too.
Old 08-02-2002, 08:14 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Hooker or SLP.
TreDeClaw
Theoretical and Street Racing
06-22-2021 08:21 PM
Reddeath210
10-06-2015 08:20 AM
Wvcamaro
09-04-2015 08:38 PM
mdtoren
08-16-2015 05:45 PM
mustangman65_79
08-07-2015 09:55 PM
Quick Reply: What is a good brand of header
