Vacuum pump to check brake booster?
Old 06-30-2002, 07:41 AM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
I was wondering if I can use a handheld vacuum pump to check if my brake booster is bad. If so, what is the usual vacuum reading as you pump, ie. max vacuum it'll hold. I did a "trial" run with it and got around 11 inches of vacuum, after many squeezes, and that was max. Any help or suggestions would be great, thanks.
Old 07-05-2002, 03:01 PM
jmd
jmd's Avatar
Car: `86 SS / `87 SS
Did it hold for a while?
Can you only put 11psi vac. on another device with the pump?
If yes to both, then you're good.
Old 07-06-2002, 12:07 PM
Car: 1982 Z-28
Engine: 383
JMD,
Thanks, I re-checked it and it doesn't hold.
I also checked the pump and I can pump it up to the max pressure. It's a brand new pump.
It looks like the brake booster may be shot...
Old 07-06-2002, 02:26 PM
AFrikinGoodTime's Avatar
My booster is only 6 months old( still brand new) and it only holds 10-10 1/2 in. of vacuum.
Old 07-07-2002, 08:00 AM
Car: 1982 Z-28
Engine: 383
Where did you pick up this new brake booster? Maybe you can take it back for another one.
I read on another post that car craft was saying there new power brake booster holds up to around 18" in vacuum. I've checked my books and cannot find anything on how much vacuum these things should hold.
jklein337
09-19-2018 06:23 PM
Infested
05-22-2018 11:56 PM
pigpete
Exterior Parts Wanted
08-15-2015 07:56 AM
MustangEater82
Brakes
08-11-2015 07:52 AM
Quick Reply: Vacuum pump to check brake booster?
