Best chemical to spray on rusted bolts?
Old 05-24-2002, 08:30 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
What have you guys found to be the best thing to spray on rusted bolts to loosen them up?
Old 05-24-2002, 08:33 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
PB blaster works well for me!
Old 05-24-2002, 08:49 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
ditto
Old 05-24-2002, 09:42 PM
2vmodular's Avatar
if penetrant oils don't work, the flame from a torch often helps.
Old 05-24-2002, 11:36 PM
TonyZ83's Avatar
Another vote for PB Blaster. Best stuff I've used so far.
Old 05-24-2002, 11:38 PM
Jza
Jza's Avatar
My personal order of preference for penetrating oils:
1. PB Blaster
2. Liquid Wrench
3. WD-40
And if you can spare the time, definitely hit it, let it sit overnight, then hit it again before your start work. Worth the wait if you're not rushed or on a schedule (got school or work in the morning).
Old 05-24-2002, 11:40 PM
Buck268's Avatar
PB Blaster...hmm... never heard of it... how's it stack up againt wd-40 (and the like)??
Old 05-25-2002, 12:14 AM
Jza
Jza's Avatar
Compared to PB Blaster, WD-40 is like just spitting on the bolt.
Old 05-25-2002, 12:17 AM
Buck268's Avatar
*drools*
Old 05-25-2002, 12:18 AM
Joshua Leslie's Avatar
PB blaster!! woooooohoooo!! have saved me many a times!!!
Old 05-25-2002, 12:36 AM
rezinn's Avatar
PB Blaster is great stuff, we used to use it in kragen to free rusted water pump studs. Just let it sit on the bolt and work it around in there. Be patient and it will help!
Old 05-25-2002, 12:52 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
PB blaster is something else (certainly smells like it). I used it when i was removing my old manifolds off my gta and after that stuff did its business you could practically hand-loosen them. Liquid wrench and WD40 work pretty well too...
Old 05-25-2002, 02:50 AM
titeride85's Avatar
Ever tried 409? works damn well. eats rust right off the bolt. you have to let it sit for a while though. it really works wonders on chrome.
Old 05-25-2002, 03:22 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
At my former work site (General aviation maint) we tried everything on exh manifold bolts/studs and wound up using a product called "Mouse Milk".
It works great on rust, but it's expensive ($17 for 8 ozs a few years ago) and really hard to find.
I bought a bottle abt 8 years ago and still have abt 1 oz left..
It goes a looong ways.
I used it recently on my sway bar end links.
They haven't been apart in 20 years, but came right off using the mouse milk.
If anyone is interested,
it's distributed by:
Worldwide Filter
1689 Abram Cr
San Leandro, Ca 94577
Old 05-25-2002, 10:04 AM
BuckeyeROC's Avatar
Haha, that is one of the reasons why I asked. I sheered off both of the rear sway bar end links from my Bird b/c they were so rusty.
Old 05-25-2002, 11:14 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
PB Blaster again! That stuff is awesome.
Of course since I've moved from OH to GA I don't have a problem with rusted anything. My can of PB Blaster is collecting dust on the shelf.
Old 05-27-2002, 09:54 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Kroil or aerokroil
615 833 4101
www.kanolabs.com
1000 S Thompson Ln.
Nashville, TN 37211
I don't know how much it costs per can, but I use it at work (powerplant) and it works wonders on getting off bolts that have been in 2000*+ heat and years worth of ash build up.
I'm going to look for that Pb Blaster though, seems like a lot of people have been happy with it.
Old 05-27-2002, 12:57 PM
RJR99SS's Avatar
the absolute BEST way to get a rusted, or any stuck bolt out is to hit it with a torch and get it cherry red. Then as soon as its red hit it with your penatrating fluid.
I used to do that to get oil gallery plugs out....after you do that they come out like they were just put in there....
Old 05-27-2002, 01:59 PM
FJK
FJK's Avatar
Kroil !!! No question about it. Get it from an industrial hardware suppy or the website BEAST mentioned.
Old 05-27-2002, 06:18 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
PB blaster is my best friend.
Mouse Milk
poor mouse
Old 05-27-2002, 07:35 PM
ede
ede's Avatar
heat from a torch or co2 from a fire extingushier
Old 05-27-2002, 10:52 PM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
Yup, PB Blaster or Kroil are good choices.
Another good technique is to heat with torch, and then zap them with 'Freeze Spray' which is used for troubleshooting electronics. Get it at Radio Shack. I dont reccomend re-using any bolt you try this on though, as the rapid heatingcooling cycle may sometimes crack the bolts. I split a 3/4" dia. grade 5 set screw doing that once.
Old 05-27-2002, 11:11 PM
ebmiller88's Avatar
Never heard of PB Blaster so I'm no help there, but Kroil is the cat's ***...period. This stuff could loosen up my ex!!
www.kanolabs.com
Old 05-27-2002, 11:17 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
Used to use Kroil and that works good. But I've switched to Deep Creep now seems to work a little better. Many times i can remove the nut from the manifold studs with my fingers after breaking loose. Deep Creep is a Seafoam product.Havent tried blaster yet Creep works too good to change.
Old 05-28-2002, 06:01 PM
SkyWarrior's Avatar
Car: 1986 Pontiac Trans Am
Engine: 305 LG4
Transmission: Borg Warner 5 Speed
I vote for PB Blaster.
"oh yeah, you can milk anything with nipples."
Old 05-28-2002, 08:48 PM
bob8748's Avatar
The mouse might like it, Can picture in my mind a company with all the mice on their back with feet in the air...lol. Formula 409 huh? Will try that.
Old 05-28-2002, 09:02 PM
BuckeyeROC's Avatar
"Oh yeah, can you milk ME? I have nipples." Haha, "Meet the Parents".
I bought some PB Blaster and it worked pretty well on 2 of the bolts. I still had to use a torch on a couple bolts and a hacksaw on the sway bar endlinks. This car was pretty rusted underneath.
Old 05-28-2002, 11:30 PM
ebmiller88's Avatar
From experience with my 2 cars, the end links should be destroyed and replaced anyway.
Old 02-03-2008, 10:29 PM
SoSoFresh_SS's Avatar
Car: 1984 Firebird
Engine: 2.8L V6
Re: Best chemical to spray on rusted bolts?
after stripping my alternator bolt suing the ratchet is the next best bet a vice grips? I sprayed it with pb blaster and its soaking overnight...any suggestions
Old 02-03-2008, 11:41 PM
SkyWarrior's Avatar
Engine: 305 LG4
I suggest using a pry bar to take some of the stress off the bolt before you vise grip it. and yea vise grip it, as tight as you can get them. SO tight that if they pop off the speed with which they pop off causes enough friction to make the air around them as hot as the sun.
deracer
04-11-2016 12:04 AM
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
billybob6110
09-23-2015 01:30 PM
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
Quick Reply: Best chemical to spray on rusted bolts?
