Removing rivets inside door ?
Old 04-23-2002, 08:16 PM
ronterry's Avatar
Car: '94 Corvette
What do you guys use to remove those rivets deals that hold power locks, etc. on the inside door.
They look like pop rivets, but have a screw extending outwards. This make drilling them imposible.
I was able to remove two that hold the door lock actuator, but I use a cutting blade right threw the center. Took forever cause the rivet still didn't want to let go !
The rivets are flush against the door making it imposible just to cut the heads off.
Is there a specail tool ? What the hell do you guys use ?
I'm about to glue some M-80's to the ^astards !
It's bad enough feeling up the garage with cutting head dust. arrr
Ron
Old 04-23-2002, 09:27 PM
ede
ede's Avatar
grinder
Old 04-23-2002, 09:29 PM
ronterry's Avatar
Car: '94 Corvette
Old 04-23-2002, 11:11 PM
2vmodular's Avatar
when i did the manual -> power window conversion i had to remove several of the 1/4" rivets.
i used a variety of tools for the task
first an electric grinding wheel to grind the rivet heads flat
then a punch to hit the center stud out of the rivet
finally an electric drill to drill the rest of the rivet out
in salvage yards, i've seen people brute force the rivets out of doors using a hammer and chisel or a big prybar. but the doors are usually junk anyways and it doesn't matter if the door is damaged in the process of removing a lock actuator or window regulator.
https://www.thirdgen.org/techbb2/sho...threadid=99665
https://www.thirdgen.org/techbb2/sho...threadid=99525
https://www.thirdgen.org/techbb2/sho...hreadid=101631
Old 04-23-2002, 11:53 PM
ronterry's Avatar
Car: '94 Corvette
Forget it !!! I've got a better, and quicker solution !!!
Just kidding. I'm going to try that tommarrow, luckly I'm just gutting the doors --- no more, no less.
Thanks guys,
Ron
Old 04-23-2002, 11:57 PM
ronterry's Avatar
Car: '94 Corvette
Forgot to add... The picture above is my high tech gm unusual door rivet thingies - removal tool.
Old 04-24-2002, 08:21 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
...guess nobody gets the money now. Thats one of those new plastic keys...THE KIND THAT SHRED!!!!!
Frozer!!!
01-19-2024 04:55 PM
Vintageracer
01-10-2020 05:33 PM
Out-Cast
08-23-2015 06:33 AM
BlackTopKing
08-19-2015 12:13 PM
3rdgenparts
08-08-2015 07:09 PM
Quick Reply: Removing rivets inside door ?
