How Do I lean out, an Edelbrock?
Old 06-04-2001, 03:56 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I think I am running rich, poor gas milage and high emissions readings. How do I go about leaning out the carb., can I play w/ the A/F screws, if so which way do I turn them, I thought left but am not sure.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
Exhaust Cut-Out
"There is nothing more addicting than speed"
Old 06-04-2001, 07:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
The screws will only adjust the idle mixture and will have little effect on your mileage. You'll have to change rods and jets to lean out the cruise mixture. Edelbrock has the manual online at http://www.edelbrock.com/automotive/eps_intro.html which explains pretty much everything.
Old 06-05-2001, 07:55 AM
FastBroker's Avatar
Yep. I recommend purchasing the Tuning Kit for your specific carb. Plenty of jets and rods and springs and good directions on how to get what you want.
Pac J
05-17-2020 10:44 AM
Mark_ZZ3
05-24-2018 01:02 PM
armybyrd
Carburetors
10-20-2015 03:57 AM
efiguy
09-27-2015 01:30 PM
Night rider327
09-25-2015 04:47 AM
Quick Reply: How Do I lean out, an Edelbrock?
