instructions for 750 edelbrock 1407
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey guys i have a 750cfm edelbrcok carb (1407) it cam with my 350 but it was new in the box but had no instructions so i need to know wut all the little ports do and all the adjustments. well if any1 has this carb i would be very thankful if u could scan the pages for me or let me know were i can find one. thanks
Check on www.edelbrock.com I think they are on there
Car: 89 Formula
Engine: Carbed 5.7
ok 29 people looked and only one response? come on guys i need these instructions or at least a diagram of where to hook each thing up. the edelbrock site has nuthin.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I don't have one of those carbs, know a couple of people who have run them, but looking at the above referenced site, I see:
1) The big vacuum port in the front lower center is the PCV port.
2) To find the vacuum advance port, they give these instructions:
"To select the proper distributor vacuum port on your Edelbrock carburetor, we suggest the following procedure to locate the correct outlet. Before removing your old carburetor (with the engine warmed up to operating temperature and idling), pull the hose off the port that routes to the distributor vacuum advance canister. After the hose has been removed from the carb, place your finger over the vacuum outlet. If, (at idle), you feel your finger being sucked in toward the carburetor, you have full-time vacuum advance. If you don't feel any vacuum pulling at your finger with the engine at an idle, you have timed/ported vacuum advance."
You probably want timed/ported vacuum advance. Use the same procedure to find it on the new carb.
The adjustments are well covered on the site. No need to copy them here, look for yourself and copy/print as required.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
http://www.edelbrock.com/automotive/eps_intro.html
Engine: LS1/LQ4
Now, be nice to the poor guy. You're starting to sound like me, and you don't want that...
Took me a month to go look at the Holley site, found most of the answers to the questions I'd had (and straightened out some misinformation I'd received).
Car: 88 IROC-Z
Engine: 383 Stroker
The front left port is for timed vacuum, the one on the front far right is manifold vacuum and the one on the back is manifold vacuum (where I plugged my brake booster into).
:hail:IROC-Z
:hail:IROC-Z
Engine: 383 Carb
Car: 89 Formula
Engine: Carbed 5.7
what exactly is timed vacum? also with the ports i don't use should u just cap them or no?
Car: 88 IROC-Z
Engine: 383 Stroker
The timed vacuum port is where most people put the vacuum advance hose. At idle there should be no vacuum at that port. As the butterflies open, vacuum from that port rises to get more timing advance under initial load (take off). I use the far right port where there is full vacuum at idle for my vacuum advance distributor to have full advance (except for centrifugal) at take off. I get better results with it that way while others prefer the timed advance port. And yes, cap the ports you don't use or you will have a vacuum leak.
:hail: IROC-Z
TO HELL WITH VACUUM LEAKS
:hail: IROC-Z
RedLeader289
05-28-2019 01:47 PM
Night rider327
09-25-2015 04:47 AM
