LT1 T56 issue details inside help appreciated thanks
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
Any info help is appreciated 5107061708 u can text me to let me know any info thanks again.
The car has a 355TPI with t56 issue happened after throwout bearing was swapped for a precision brand. I removed it and I put the one that came.with clutch kit just got it repacked with grease. Drives fine but at idle between 1000 to 1500rpms it makes a metal noise not sure if its normal I dont think it is because I never heard it before.
New parts put on are competition clutch kit stage 2, fork, pivot/pivot bolt, fluid, and the t56 has been rebuilt because I took it to a shop to figure the noise out and they said it was a bearing on the input shaft which the trans shop said nothing was wrong but I told them to replAce them and clean it up and replace anything else needed. So far ive spent around 1600 in the new parts.
I have left to replace if needed the slave cylinder and flywheel.
1992 Trans Am
08-08-2015 08:16 PM
rsrmoore
08-07-2015 08:44 PM
