Quest for a better flowing TPI
Old 07-02-2018, 01:09 PM
  #351
Re: Quest for a better flowing TPI
Don are you referring to extending the ve tables ?
https://www.thirdgen.org/forums/diy-...ve-tables.html
Old 07-02-2018, 01:45 PM
  #352
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
No, Just using a different bin file.
AXCN for SD starting a new project or combination.
APYP for MAF starting a new project or combination.
We were using AXXD where the problem occurred.
Old 09-03-2018, 04:55 PM
  #353
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Originally Posted by no new tires
Where's the new chart, time to pony up.
This is what he talking about. The first video is with the 305manual program. This was used because GM didn’t make an F-Body 350 manual program and only program up to 5600. But they made it in the Corvette manual program in which can be programmed to 6400.
This video is the Corvette 350 manual program.
LT1Formula
20
11-14-2015 12:02 AM
gta90
09-15-2015 04:00 PM
Keith5
08-27-2015 04:37 PM
theurge
08-21-2015 12:46 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: Quest for a better flowing TPI
