Dual Cold Air Intake
Old 03-24-2014, 06:51 PM
TAYLOR18's Avatar
Car: 1985 IROC Camaro
Engine: 5.0L 305
Ive seen these twin/dual cold air intakes on corvettes, and I thought they look really cool. Does anybody know what id have to do to get one of these things to fit on my 85 iroc. it would also be good to know if they work. If not suggestion would be great. Thanks
Attached Thumbnails Dual Cold Air Intake-imagescacd07t4.jpg   Dual Cold Air Intake-mvgqoznxquj3uokea5axrga.jpg   Dual Cold Air Intake-imagescap9czkf.jpg
Old 03-25-2014, 09:36 PM
Mad Myche's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
Re: Dual Cold Air Intake
Don't you currently have the factory dual air filter on your engine? If so you are better off with that most likely than messing around with that.
Old 03-26-2014, 06:56 AM
TAYLOR18's Avatar
Engine: 5.0L 305
I do, Are you saying that the power gains from switching out OEM Intake isn't worth switching it out?
Old 03-26-2014, 07:09 AM
Prolly not a huge gain on a stock-ish motor. Have you moded the stock lower airbox yet?
Old 03-26-2014, 09:40 AM
TAYLOR18's Avatar
Engine: 5.0L 305
No I have not, should I?
Old 03-26-2014, 10:01 AM
carattini's Avatar
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
that is not a cold air intake. to be it have to draw air from outside the engine bay
Old 03-26-2014, 10:37 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Old 03-26-2014, 11:35 AM
Van Nuys born's Avatar
Car: 4/89 IROC Z28 G92 -
Engine: LB9 TPI
Axle/Gears: 3.45
The engineers knew what they were doing with the dual outside air intake on the Iroc's .... Cool dence air is what you want. Drive your car on a warm day and then a cool evening and the difference is even more noticeable.
Old 03-26-2014, 07:08 PM
It would most likely pick up more HP than the thing you want fab up.
Old 03-26-2014, 09:50 PM
Mad Myche's Avatar
Car: 89 Camaro RS
Engine: 2.8 V6
The only thing wrong with the factory setup you have is finding replacement standard air filters for it; that's about the only reason I have K&Ns
Old 04-15-2014, 12:42 PM
Sam L.'s Avatar
Car: 1990 Camaro Iroc-z Z28,1987 Camaro
Engine: 406 Super rammed SBC, LT1 355
Transmission: 4l60E, 700R4
Axle/Gears: disc brake 3.27 9 bolt posi,10 bolt
just modify the stock set up i gained 8hp modding the stock intake i lost about 12 with a custom intake cause its so hard to pull "cool" air on our cars
Old 04-17-2014, 09:51 AM
Hlvo13's Avatar
Car: 1989 pontiac firebird formula
Engine: 5.7 350 tpi
Transmission: 700r4 i think
im looking to ad an intake to y 89 formula, what would be the best for hp? and how would you fit a cold air intake to it?
Old 04-17-2014, 07:06 PM
Its best to start a new thread.
I would look for a used (no more new ones) SLP airbox, its about the best.
1992 Trans Am
05-10-2023 07:19 PM
Brinkkl2000
08-04-2018 08:29 AM
stalkier
12-06-2015 11:25 PM
hayesaw0210
08-23-2015 11:15 PM
kyle5647
08-15-2015 11:56 PM
Quick Reply: Dual Cold Air Intake
