High idle at startup
Old 04-18-2014, 07:18 AM
pontiacdog's Avatar
Car: '86 Trans Am
I recently adjusted the ignition timing to 6 degrees, which I think is correct for this vehicle.
I did it at 220F operating temperature.
Otherwise the car runs fine but when I start it, the idle is at 1400rpm which is very high...
When I put it in gear (automatic transmission) the idle is suddenly normal.. and even if I put it straight back to parking gear, the idle stays normal. So the problem occurs only when I have just started the car, and the idle won't drop to normal readings even if I gave the engine some time to warm up.
Is this an ignition timing issue or something else..?
IROCtometal
09-20-2015 11:08 PM
IROCtometal
09-09-2015 10:01 AM
bamaboy0323
09-03-2015 06:07 AM
IROCtometal
09-02-2015 02:01 PM
Quick Reply: High idle at startup
