V6 to V8, installing OEM dual fans, what temp on/off for switch?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ordering a fan relay/temp switch/harness install kit and there are many different combos.
83 Firebird with a 350 swap. Running OEM TPI dual fans. Basic setup.
I'm up in New England so most days aren't going to be scorching.
Car isn't driven in the winter.
Won't be seeing much racing, just daily use for the most part.
Options for fans on: 176/180/185/195/210
Options for fans off: 161/165/170/175/190
Was thinking this one: http://www.summitracing.com/parts/sum-890014/overview/
Thoughts?
Thoughts?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Re: V6 to V8, installing OEM dual fans, what temp on/off for switch?
Ok cool, that's exactly what I needed to know. Wasn't sure where the old 350 was happiest!
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
http://www.summitracing.com/parts/rfw-ar99/overview/
Ended up with this one. Fully adjustable! I'll post results soon
The_Phoenix
02-04-2016 07:10 AM
TA8487
08-16-2015 12:21 PM
eightsixseven
08-14-2015 03:09 PM
