Proform Water Pump Leaks
Old 04-16-2014, 02:01 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Anyone else have this problem? It only seems like it does it after the car sits for a while. I watched it last night and it didn't leak a drop, this morning a small puddle underneath the thing.
I google'd the issue, and there are a few threads about the issue. Anyone seen this issue on theirs? It's just enough to be an annoyance .
Old 04-17-2014, 07:45 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Proform Water Pump Leaks
If it leaks from the block area, can you double gasket it?
Old 04-18-2014, 06:33 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
I went through two proform electric water pumps for sbc. Both leaked from the weeping hole (small hole on the bottom side above the crank pulley) and when the weeping hole weeps coolant that is a premature sign of future seal failure.
Switched to a meziere and all is well.
evilstuie
01-09-2020 08:29 PM
evilstuie
04-14-2016 08:52 PM
Bubbajones_ya
08-28-2015 02:17 AM
1985chevydude
08-22-2015 05:36 AM
Dialed_In
08-20-2015 01:45 PM
Quick Reply: Proform Water Pump Leaks
