Timing Chain Replacement
Old 04-15-2014, 05:02 PM
305_firebird's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: L98 TPI 350 Originally 305 TBI car
So I've come to the conclusion that I need a new timing chain/gears. I took the dist cap off and I have probably 10-15 crank degrees of lag. My engine has 193k on it so I'm not surprised. Anybody have any clever tricks to keep the crank from rotating to manually loosen the crank pulley bolt?
Old 04-15-2014, 09:18 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: 383-Holley Terminator EFI
Transmission: 700R4 Pro-Built Street/Strip kit
Axle/Gears: Strange S60 3.55:1
Re: Timing Chain Replacement
Lock the flywheel with a screwdriver, or use one of those band straps around the harmonic balancer.
Old 04-16-2014, 06:56 AM
ex-x-fire's Avatar
I have an old compression tester hose that I removed the valve, the hose hooks up to shop air. Screw that into a spark plug hole & turn the engine over by hand, once the valves close there should be enough resistance to loosen the crank bolt.
Old 04-16-2014, 11:35 AM
ploegi's Avatar
Engine: 5.7 TPI
Don't use a strap wrench on the balancer. It could slip, then you would be in real trouble. Impact wrench works really well if you have air....
Old 04-16-2014, 07:42 PM
Lurbie's Avatar
Car: 89 Camaro
Good point on the strap, hadn't thought of that, the screwdriver always worked for me. I couldn't fit my impact gun in their on mine, it was too long with the radiator still in.
Vintageracer
01-10-2020 05:33 PM
NBrehm
08-25-2015 11:49 PM
drewdock87
South Central
08-18-2015 09:02 PM
MY87LT
08-17-2015 08:43 AM
Leggman1
Brakes
08-12-2015 08:39 PM
Quick Reply: Timing Chain Replacement
